engine replacement for 02 oz.
Old Feb 5, 2011 | 01:09 PM
chaoz1212's Avatar
Unhappy engine replacement for 02 oz.
im going to start off by saying that i know very little about engines and im afraid im going to be financialy raped by the dealer, my car is already in the shop cause i couldnt get it running, they told me today that i bent my valves and maybe put a hole in my piston? they told me i need a new motor. which im sure theyd be willing to sell me for a **** ton of money. anyways if thats the case what motors could i get that will be inexpensive to buy and install but still give me a little boost in HP. and or would it be cheaper and less of a hassle to fix the engine thats in it? it had about 137k mi on it.
Old Feb 5, 2011 | 02:15 PM
03lances's Avatar
If you are willing to search and have patience you can save a ton of money. You should be able to find a gaurenteed runner from a salvage yard for around $500. They may want your engine for a core but not like its doing you any good anyways.
As far as your question to the amount of hassle and expense to fix your current engine. Well that depends on the actual extend of the damage. I assume the timing belt broke on this particular engine correct? I haven seen many timing belts break and have yet to see a damaged piston, (although not impossible for sure) usually just bent valves. Also since you have it in a shop I can assume your mechanical knowledge is probably basic which means paying someone else to determined the extent of the damage and repairing it. My opinion would be to get another engine and replace if your unable to determine the problem yourself as thats where the big $$$ can come in to play.
Old Feb 5, 2011 | 02:20 PM
chaoz1212's Avatar
first off, sick car. and second its at the Mitsubishi dealer ship in town. but im gonna look around for a new engine now. is their like an easy drop engine with more HP then the stock 2.0 oz rally motor (gonna look up what it is now)
and thanks btw.
Old Feb 5, 2011 | 02:51 PM
zulu989's Avatar
eclipse motor i think but that might be too much for u to handle, or a galant motor, idk just use the stock one
misha205
Nov 14, 2016 09:06 AM
BernY
Jul 3, 2013 08:45 AM
carlmoore3
Apr 2, 2013 07:04 PM
Jmoney707
Apr 30, 2012 03:44 PM
ozrallyrace
Jul 21, 2011 02:13 AM
