4G93 Intake Manifold on 4G94 (Fuel Rail not flush)??
Old Jun 18, 2011 | 07:21 PM
  #31
lil' jeff's Avatar
yea theres one...and my brother but mostly do all my own work and research.
Old Jul 6, 2011 | 12:46 PM
  #32
Photool's Avatar
UPDATE:
Sorry for late update. been workiing alot on the 240sx. Installed new injector seals and orings.
So far idle is back to normal and air sound is less noticeable.
However, still hearing some kind of air leak. Hard to tell where it is coming from.
Going to do a couple compression tests and vaccum leak tests.
Trying to work all the kinks out before I turbo the car.
Old Jul 11, 2011 | 01:48 PM
  #33
Token's Avatar
might wanna check the little hoses around the throttle body. when i did mine, i had to add some small zip ties to the equation.
Old Feb 23, 2015 | 05:48 PM
  #34
Photool's Avatar
I've been messaged a couple times and just for the sake of other people who might run into the same issue I will post this:
I added spacers where the fuel rail mounts and with some minor adjustments the fuel rail issues were resolved. The air leak sound was a nipple on the side of the manifold that I had to plug and also the brake booster line that was extended had some air coming out of the connection.
I've been running the car with my ported intake manifold for 4 years with no problems and no tune. It does lack a little bit of acceleration but once it gets into the higher RPMs it has a nice pull. Hope this helps.
mitsuorder
Sep 20, 2021 06:05 AM
Blacksheepdj
Lancer-Mirage Compatibility Forum
107
May 1, 2015 06:21 AM
ambystom01
Jul 20, 2014 03:55 PM
lilazn64
Lancer Aftermarket Forced Induction Tech
20
Sep 7, 2008 01:43 PM
GreenPsycho
62
Oct 25, 2005 05:10 AM
