when is a FMU needed ?
Old Jan 5, 2004 | 09:21 PM
Probleminfected's Avatar
when is a FMU needed?
i've never had to use one before, but then again, i'm not from the import world.
Old Jan 5, 2004 | 09:23 PM
jon_e_blaze's Avatar
sorry for adding questions to your thread, but what is an FMU?
Old Jan 5, 2004 | 09:24 PM
fuel management unit.
Old Jan 5, 2004 | 09:26 PM
Guru_Del's Avatar
when you get into turbo or the need for more fuel under load than is handled by the stock system.
Old Jan 9, 2004 | 09:39 AM
HobieKopek's Avatar
Basically what Vince said. To add to that though, 1. you don't need to raise fuel pressure unless your injectors are running too high of a duty cycle or you are otherwise unable to flow enough fuel. and 2. They work off boost pressure, so unless you're running positive boost pressures (a la forced induction) they're pretty much just useless. Someone may correct me on that, but I'm pretty sure it's accurate.
Old Jan 12, 2004 | 04:01 PM
sdhotwn's Avatar
I concur with andrew.
Old Jan 12, 2004 | 04:05 PM
Tanner65's Avatar
Just to sound smart....
I concur...
crf inc.
Lancer Aftermarket Forced Induction Tech
10
Jan 15, 2010 10:25 AM
kungfugirl
Lancer Engine Tech
30
Jul 31, 2007 09:10 PM
Racer24x
Lancer Engine Tech
Apr 30, 2007 04:11 PM
Johns Slow ES
Lancer Engine Tech
10
Oct 27, 2005 01:26 PM
airlinevomitbag
Lancer How Tos / Installations
Jun 30, 2003 07:52 AM
