Boosting my 03 ES
Old Nov 10, 2011 | 11:41 PM
chronotrip21's Avatar
Boosting my 03 ES
ok guys, now that i have read up on a few turbo guides on here, i gots some questions..
first, is a TD05 16g turbo a good turbo for a 03 lancer ES? if not then whats better..
Also, can someone tell me what a GOOD fuel pump would be. Ive heard TRE 255 and Walbro 255 are good...
Injectors...Whats some good ones..
And lastly a new Clutch for my 03 Auto. i want to keep my Automatic Tranny, but what will i need besides a better clutch to be able to run a turbo'd setup on my car?
PS. i would like to hit about 300hp if i could.
thanks
Old Nov 10, 2011 | 11:47 PM
03lances's Avatar
BTW to add to my pm You need walbro 255 GSS342, make sure its the 342
Old Nov 11, 2011 | 12:04 AM
cool, any other advice as to what parts would be good to use, remember im buying parts a little at a time
Old Nov 11, 2011 | 08:51 AM
ThunderOZ's Avatar
The 16g would be ok and definitely cheaper than other options but looking into a larger turbo wouldn't hurt.
The auto doesn't use a clutch, but you can get a level 10 torque converter to help the transmission.
To hit 300, you're going to have to swap out the internals of the motor. You just might be able to hit it once without doing so but the engine will grenade at that high of a stress level(about 3x stock hp)...
Old Nov 11, 2011 | 07:58 PM
CrAnSwIcK's Avatar
at moderate boost, a lot of guys are getting away with oil coolers, rather than swapping the torque converter. if you're going to upgrade the TC, you may as well rebuild the transmission, and that will become increasingly expensive if you can't do the work yourself.
Old Nov 12, 2011 | 06:46 AM
Boston_eagle's Avatar
I had an upgraded TQ converter on an old GSX. It was able to hold a good amount of power.
The td 05 will be a good choice; the spool will be quicker than a higher hp turbo. Power is not the end all; driveability and decent spool time (read less lag) are also options to consider if you will be driving the thing other places than the track.
Old Nov 13, 2011 | 02:11 AM
yeah, i plan on driving it as my daily, but i wouldnt mind being able to have some extra power in it, thus the smaller TD05 turbo. but what are you guys opinions on parts that i might need to hit that almighty 300 that i want?
pdizzle
Lancer Tranny/Drivetrain Tech
Jul 26, 2010 07:05 PM
dspucches
Jun 3, 2010 05:28 AM
CMcraz23
May 20, 2008 01:18 PM
lemonAJAX
10
Jun 15, 2006 10:54 AM
zcyph
Feb 27, 2005 03:37 PM
