4G93 Intake manifold
Old Jan 3, 2012 | 08:45 PM
jujukiller's Avatar
First of all: Before you troll: I know that the 4G93 manifold doesn't REALLY give power gains and that the only real way to get big power gains would be to go turbo. Even though I don't plan on going turbo (moving to europe in a year) I still want to get a 4G93 manifold and port it out, but before I do so I have a couple questions.
Will a 1.5L 4G93 intake manifold work?
Does the swap involve deleting cruise control?
EDIT:intake has been installed the pictures are towards the bottom of the page. And to anybody who is thinking about getting one, DO IT, you just have to be patient (porting is a time consuming process), it sounds awesome (almost boxer engine) and gives a little more power towards 3,5k rpms.
Old Jan 5, 2012 | 05:24 PM
jujukiller's Avatar
DELETE!!! I found a 1.8 intake mani
Old Jan 13, 2012 | 05:14 PM
OZR_Lancer's Avatar
u dont really want a 1.5l mani lol on a 2.0l block
Old Jan 13, 2012 | 09:14 PM
MurphDurph's Avatar
did you get the cam too?
Old Jan 14, 2012 | 12:00 AM
jujukiller's Avatar
a 1.8l 4G93 cam? is it better than ours?
Old Jan 14, 2012 | 08:36 AM
*02Lancer*'s Avatar
I use to have the url but I cant find it. It showed the The 4g93 camshaft specs vs the 4g94. *I believe* It is the same as one of the stage 1 camshafts from a company. I have one laying around I got from a junkyard but I never installed it and dyno's it to see if it really helped.
Old Jan 19, 2012 | 09:21 PM
jujukiller's Avatar
Just got my intake manifold in the mail here are a couple pics of it. And I will be getting a black and decker rotary tool this weekend so I will clean and port it once I get the tool.
I only have one question (already read all of the how to's to do the swap) can I recycle any of the parts (vacum lines, sensors or valves) off of the manifold that came off the mirage?
Old Jan 19, 2012 | 09:37 PM
jujukiller's Avatar
Oops forgot the pics:
Old Feb 2, 2012 | 03:23 PM
jujukiller's Avatar
Well finished the install, and had a thorough test upon installation, I went autocrossing the next morning after the install , I didn't have any engine codes, weird idle or leaks, until a day after autocrossing my idle went up to 1000rpm and I have 2 codes P0507, and P0507 pending??
OH, side note when you port don't forget to spray WD-40 and wear a mask, otherwise you end up with a aluminum lollipop (picture below).
But anyways here are a couple pictures of the cleaning, porting and installed.
After cleaning and port marking
[IMG]ttp://img827.imageshack.us/img827/9863/cleanmani.jpg[/IMG]
there goes 10 bucks
Learned my lesson
Before (left)/After (right)
DONE!
****ty fabrication
Old Feb 2, 2012 | 04:00 PM
slatermvp's Avatar
I gotta fabricate something for my throttle cable since I'm using a mirage cable at the moment.
Old Feb 2, 2012 | 04:26 PM
jujukiller's Avatar
It's really easy I just went to home depot and bought that angle and just drilled an extra hole.
Old Feb 3, 2012 | 08:16 PM
slatermvp's Avatar
Imma do that.
Blacksheepdj
Lancer-Mirage Compatibility Forum
107
May 1, 2015 06:21 AM
LimitlessEvo7
Nov 9, 2014 02:53 AM
ambystom01
Jul 20, 2014 03:55 PM
TTP Engineering
45
Dec 1, 2009 12:32 PM
GreenPsycho
Lancer Engine Tech
66
Jun 28, 2009 07:59 PM
