Radiator + Thermostat options
Well my radiator finally gave out and it is time for a new one. Never had to buy one before and have no clue where to look.
I have seen Koyo, Silla and CSF type radiators online for decent prices (all under $150). The mishimoto is out of my spending range @ $270.
Also need a new thermostat, should I grab an aftermarket one (like gates or mishimoto) or go to mitsu and grab a OEM one?
i would go with an aftermarket thermo, as for the rad have you checked the used section?
i got a mishimoto and love it, one done fall is it really thick!
depends on what your doing with the car. if its just DD and spirted driving around town a KOYO OEM re placement if perfect and low cost.
I bought an ebay radiator all aluminum evo 5 style I believe it was around $160 much better than stock. Been running it for quite awhile now works awesome and way thicker core too. As far as the thermo goes I always just go with the aftermarket fail safe style (locks open if it fails instead of closed where you can do some serious overheating)
I have a megan but would probably recommend something else. Definitely look into a aftermarket thermostat. During the summer time my lancers temps go up when its just left idling for a while
. I might put a colder thermostat in when I start installing my turbo. If you go aftermarket you might want to decide wether you want a pusher or puller set up (depending on what your going to do performance wise).
I'm getting a similar one as 03 its $153 with 2 fans!
http://www.ebay.com/itm/260894204584...84.m1497.l2649
gilevo7
May 20, 2017 10:55 PM
InoNothingMR
For Sale - Miscellaneous Automotive
10
Dec 5, 2012 09:17 AM
