Mivec
Old Jan 29, 2004 | 03:34 PM
check_valve's Avatar
Mivec
Hi guys,
I'm looking for 4G92 MIVEC wiring diagram, any idea where to find it..?
Old Jan 29, 2004 | 05:10 PM
tenkawa_akito's Avatar
mitsu factory service manual
Old Jan 30, 2004 | 08:13 AM
Where can I find this manual. My country doesn't deal with MIVEC's...
So any specified place? I'm ready to buy it from anywhere.
Old Jan 30, 2004 | 11:03 AM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
Which Lancers use a MIVEC 4G92? This is posted in the US Lancer section, and the US Lancer has a 4G94. I would move it, but I have no idea where to! Does the US Ralliart have a 4G92?
Old Jan 30, 2004 | 10:44 PM
i thought it had a G69. But I'm probably wrong on that. Try eBay. You can find most anything you need on eBay.
Old Jan 31, 2004 | 11:06 AM
AdamJ39's Avatar
The Mivec 1.6L 175hp 4G92 came in the Jap and Aus Lancers I think only 2 doors...anyway i've delt with this guy in Ireland He has one with the Motor in it i'm sure he could get you the manual his name is Sentata...Try and get his contact info either off the mirage forums or his car is on the first page in cardomain under mirages... check it out...hes a good guy to deal with...
-Adam
Old Jan 31, 2004 | 02:24 PM
Yeah, you mean Setanta...
He's my friend... he's really agood guy... he helped in finding the ECU... BUT he don't have it.
Old Feb 4, 2004 | 10:41 AM
KillahB's Avatar
Check out the mirage forums and check for fongangus and dammit... there is another guy on there, look in the Parts section, I think his name is flyin15sec or something like that...
Both of them did MIVEC swaps and should have the wiring ...
Old Feb 4, 2004 | 09:47 PM
thanks man, I'll check them.
Old Mar 3, 2004 | 01:51 PM
Hi
I almost done with my car, but I’m getting oxygen sensor trouble code. When I trace the oxygen sensor wiring as per the wiring diagram (incomplete one), I found that the knocking sensor is already connected in the same pin.
So do I have to remove the knocking sensor and replace it with the oxygen sensor..?!
If yes, then where shall the knocking sensor goes..?!
I’m really in deep problem and really need your support.
Old Mar 3, 2004 | 09:38 PM
Dr Crash's Avatar
if you don't mind me asking, where did you get a hold of a 4g92?? i was thinking about doing the same engine swap in my car but don't know where to get one...thanks
Old Mar 4, 2004 | 06:33 AM
<<Dr Crash>>
yes I got from Japan through Bahrain.
it cost me around 2000$ without harness or ECU.
Old Mar 5, 2004 | 11:59 PM
Dr Crash's Avatar
that's pretty decent...do you have any of their contact info?? thanks
Old Mar 6, 2004 | 01:23 AM
thereasonsf3's Avatar
-Adam
thats f***ed up that they have a smaller engine and have so much more hp than us.
Old Mar 6, 2004 | 01:47 AM
bobaab's Avatar
that's the power of MIVEC...
