02-06 Lancer Engine Compatibility
Old Dec 14, 2012 | 06:10 AM
NoClanSWAT's Avatar
I have searched and found no definitive answer. I have a 2004 Lancer OZ. I have owned it since it was new. I am in need of a new engine because mine is no bueno. What year Lancer engine will fit my car? I am not looking for a performance upgrade. I am just looking for a stock 2.0L replacement. My car is a 5 speed if it makes any difference. Will any engine from 02-06 work whether the replacement came out of an automatic or manual? Thanks for the help.
Old Dec 14, 2012 | 06:41 AM
eusgen's Avatar
Is it a 4G69 or a 4G94?
If it is a 2.0 is it more than likely the 4G94 and any lancer 02-03 will have that engine.
http://en.wikipedia.org/wiki/Mitsubishi_Lancer
Old Dec 14, 2012 | 06:47 AM
slatermvp's Avatar
02-06 will work for an engine for you.
Old Dec 14, 2012 | 07:01 AM
eusgen's Avatar
Some of the 05-06 models have a 4G69 though, which is a 2.4 and easily distinguishable.
Old Dec 14, 2012 | 09:28 AM
Grind3r's Avatar
Well if his description is accurate of it being an OZ Rally, then its the 4g94....4g69 are ralliarts, not OZ's.
NoClanSWAT...if you are still unsure based off the model of your car, pop the hood. If it mivec on top of your valve cover, then its a ralliart and a 4g69...If not then its a 4g94
Old Dec 23, 2012 | 06:28 AM
Haggis1669's Avatar
New to forum and hoping am reading this right.
So basically my 2003 es snapped a timing belt so my engine is fubar
So it's a manual and I believe 4G94 engine And from what am reading anything up to a 2006 model should bolt straight in
But I cannot bolt a 4G69 into it without working on the transmission and diffs as well
Old Dec 25, 2012 | 12:14 PM
KING FILIP's Avatar
any 2002-2007 LANCER engine will fit, they're all the same. except the RALLIART trim. good luck.
Old Jun 29, 2013 | 08:53 PM
gordito_mivec's Avatar
*RARE ITEM
787-222-6738
CONTROL ARMS LANCER 02-06 (GT,SPORT BACK,OZ,RALLIART)
http://www.ebay.com/itm/271229242229...84.m1555.l2649
Old Jul 10, 2013 | 03:50 PM
smoothwis's Avatar
will the 4g94 exhaust manifold(header) work on the 4g15?
Old Jul 11, 2013 | 06:00 AM
eusgen's Avatar
I don't think it will, those are two different platforms.
Old Jul 12, 2013 | 07:45 AM
smoothwis's Avatar
Thx
Old Jul 12, 2013 | 09:42 AM
tylorshields's Avatar
what do you guys think of these spark plugs. Yes im running a fuel additive. It looks like im running rich what do you guys think. Thanks.
http://imageshack.us/a/img543/9644/24dn.jpg
http://imageshack.us/a/img832/6700/1zc3.jpg
Old Jan 18, 2024 | 08:26 PM
Corbettrallie's Avatar
When you say trim you mean body and interior correct. I ask because trim can mean different things in different countries
RobGinSki
Lancer Tranny/Drivetrain Tech
10
Aug 5, 2025 06:03 AM
doncarbone
11
Jul 30, 2015 06:12 PM
BIOHAZARDCURE
Jan 22, 2015 01:31 PM
Admaker
Lancer Engine Management / Tuning Forums
Jul 28, 2010 02:48 PM
02-Lancer-Es
Feb 6, 2009 04:52 AM
