4G93 head swap
Old Apr 23, 2013 | 12:11 PM
eusgen's Avatar
*Bows* thank you *gives points*
I still can't find where you are getting this out of the FSM though lol!
Old Apr 23, 2013 | 12:23 PM
eusgen's Avatar
Will my engine be ok a with piston like this? All my cylinder walls look good and the other three pistons are perfect thank god.
All I have to say is kids don't **** around with power tools. Just because the brush is brass doesn't mean what the bristles are attached to is brass. fml.
Old Apr 23, 2013 | 12:27 PM
todd6027's Avatar
Originally Posted by eusgen
Got another question I can't seem to get a straight answer to.
What (if anything) should I use gasket sealer on when putting the head back on? Intake, exhaust, head gasket, valve cover gasket, cam position sensor housing, thermostat housing?
Then the next question is what kind of gasket sealer? hard like Permatex Ultra Black, or non hardening?
nothing on the head gasket , pit marks on the piston ?
Old Apr 23, 2013 | 12:36 PM
eusgen's Avatar
So use nothing on the head gasket? just slap it together with the head gasket alone?
Old Apr 23, 2013 | 12:38 PM
todd6027's Avatar
yes , make sure both surfaces are clean and dry
Old Apr 23, 2013 | 12:54 PM
eusgen's Avatar
Sweet here goes nothing!
Old Apr 24, 2013 | 01:57 PM
eusgen's Avatar
Snapped a head bolt off in the block! pics to come
Old Apr 24, 2013 | 03:54 PM
Green_Bandit's Avatar
What?! OMG Man! What is going on over there?!
https://www.evolutionm.net/forums/ev...l#post10776482
Old Apr 24, 2013 | 04:13 PM
eusgen's Avatar
Luckily my threads were spared and I was able to get it out without incident. Seems the hardest thing is finding new head bolts (3 to 5 day wait at any local auto part store )
After drilling and tapping (and having the tap snap off just after getting the bolt to screw out of the block)
Old Apr 24, 2013 | 04:21 PM
jakermeister's Avatar
Are you using ARP head studs
Old Apr 24, 2013 | 04:29 PM
eusgen's Avatar
No I tried to reinstall the original OEM head bolts. Going to probably get a set of new OEM head bolts to get me back on the road. Once (if ever) I turbo I will go that route, it's not like it is difficult to remove the valve cover and replace head bolts
I did message MEGA 4g94 about his ARP studs in the for sale section so hopefully we can make a deal
I also see sets on ebay for $125 shipped
Old Apr 24, 2013 | 04:47 PM
NO NO NO! NEVER! EVER! EVER! REUSE HEAD STUDS! ESPECIALLY OEM ONES!
The ARP ones he has for sale are a deal. $100+ shipping are a bet. Second lowest price is 145 from SC.
Old Apr 24, 2013 | 08:55 PM
Use the ARP head studs man. Buy once cry once. The oem head studs stretch as well.
Old Apr 25, 2013 | 06:04 AM
02modlanceroz's Avatar
Good article explaining why not to reuse head bolts
http://www.acl.co.nz/Tech/Torque%20T...0Headbolts.pdf
Old Apr 25, 2013 | 06:15 AM
eusgen's Avatar
This was a very good read thank you
why couldn't anyone mention this before?!
