Splash Guard
Old Jul 31, 2002 | 08:50 AM
Shmoo's Avatar
Splash Guard
OK, i am installing my injen intake, and i need to know in order to remove the splash guard, do u need move a piece of plastic out of the way in order to see it?? I was informed there are 5 screws that hold it on, but i need to maek sure i am looking at the right thing. Cuttin a hole in it?!?! Is injen mad??? Can someone plz help me I didnt know the intake would be such a ***** to put in
Old Jul 31, 2002 | 08:53 AM
Shmoo's Avatar
It might sound like a noob question but its very important
Old Jul 31, 2002 | 09:00 AM
importlancer's Avatar
You trying to shove that thing into an auto?
If it's a manny tranny you should be able to weave it right up under the battery an somewhat behind the left headlight.
Old Jul 31, 2002 | 09:01 AM
Shmoo's Avatar
I tried to get it under the battery but it doesnt sit right, its a manual. I need to remove the splash guard in order to fit the filter in correctly allowing me to connect it to the pipe. I HAVE HALF AN INTAKE SITTING IN MY HOOD!!!
Old Jul 31, 2002 | 09:03 AM
Smoktout's Avatar
shmoo, dont cut anything, .....the splash guard is that black plastic piece that is underneath and towards the front of the engine. if you look around there are little plastic tabs that hold about two of these plastic pieces together. to get the tabs out, pull the top out and the entire tab piece will come out, then just put the splashguard back on when ur done
Old Jul 31, 2002 | 09:04 AM
I have not installed it (Don't drive manny), nor seen anyone install it but from the people I do know that have installed it did not have to remove the splash guard from what they have told me. So past what I my thoughts were, I can't exactly help you out.
Sorry, good luck with it.
Old Jul 31, 2002 | 09:05 AM
Shmoo's Avatar
hmm realy.....ic ic ill try that tomorrow thanx man
Malacon
Oct 25, 2016 08:42 AM
jimbo74
Apr 8, 2016 06:24 AM
Leonthefaded
Mar 27, 2016 09:04 AM
Spinsall4
May 26, 2007 05:26 AM
MR*EVO*VIII
Mar 16, 2006 10:13 PM
