Dyno'd lancers list
From what i've seen of E85 you can get a little bit better performance as it's like running a high octane. So timing and fuel can be better adjusted due to higher detonation resistance.
However you have to use a lot more of it to run the engine. Thus the bigger injectors. Essentially you don't get the mpg you get cheaper fuel. E85 uses about 20-30% more fuel than gasolene. At the price though you can run 3-4 times as many tanks than gasolene so it does save money.
The comment about the plastics is definately right... you've gotta change that line. The other components should work just fine though. Only concern i'd have is the plastic casing for the fuel pump sending unit. In time E-85 may eat it away... keep an eye on that.
Just thought I would update you guys here. Almost a year to the day since my last post here been rocking the turbo kit a year now. Pushing 12psi still stock internals, self tuned giving me a best unofficial read at
238whp
244wtrq
I plan on gettting dyno'ed this spring or sooner up at english racing
238whp
244wtrq
Hi guys i am from Pr i did 153whp /133tq and with no powersteering and ac belt did 158whp /136tq my 4g94 sohc lancer ES manual transmision did 14.8 at 90mph with 2.0 on 60ft and 15.0 at 93mph allmotor with headblock fulldone
2005 mitsubishi lancer 4g13 1.3 liter
costum turbo kit
Stainless steel mani
evo4 Tdo5 turbo
tial 38mm wastegate
tial bov
open downpipe
front mount intercooler
fc3s rx7 440cc injectors
Aem 320 fuelpump
stock fuel rail
act hd 6puk sprung clutch
stock coils
stock cam and crank sensor
adaptronic 420d ECU
car drives better then stock in slow traffic and better on gas (mpg) then stock.
anyway we made 167whp @16psi, it had stock 61whp
costum turbo kit
evo4 Tdo5 turbo
tial 38mm wastegate
tial bov
open downpipe
Aem 320 fuelpump
stock fuel rail
stock coils
adaptronic 420d ECU
