Dyno'd lancers list
Old Aug 25, 2007 | 07:46 AM
  #241
Blacksheepdj's Avatar
Has anyone run a Lancer with E85? I know that when it came up in discussion on the Subaru forums, there was usually talk of modifying the fuel system to use it. Can you just dump it in and go? Last I heard, only the "FlexFuel" vehicles could use either gasoline or E85 from the factory.
Anyone know anything, since I'm mostly guessing?
Old Aug 26, 2007 | 06:12 PM
  #242
GoSloTurbo's Avatar
i posted on the last page that i have dsm 450's and some upgraded line in my lancer and i am running e85. i pulled 115whp and 127ft lbs. before the injectors and line i was running half and half with out a problem. the only line i upgraded was from the fire wall to the fuel rail because it had the plastic center and e85 does not like plastic.
Old Aug 26, 2007 | 07:43 PM
  #243
Mirage2.0's Avatar
^Which dyno? Please post your whole set-up.
Old Aug 27, 2007 | 05:56 AM
  #244
GoSloTurbo's Avatar
i already posted, but
dynojet
k&n sri, magnaflow catback, rrm pulley, dsm 450's, e85.
Old Aug 27, 2007 | 06:14 AM
  #245
Shingen's Avatar
dynojet
So you are untuned and just running E85 with larger injectors??
Old Aug 27, 2007 | 06:47 AM
  #246
Mirage2.0's Avatar
These are good numbers. Supposly e85 bumps the power about 5%. But not 100% sure.
Old Aug 27, 2007 | 07:11 AM
  #247
GoSloTurbo's Avatar
no, i forgot to mention that i have an afc neo in it. i had it dyno tuned by the best local performance shop. they only did 4 pulls and everytime it got better numbers. they just ran out of time because they are really busy.
Old Aug 27, 2007 | 07:14 AM
  #248
Shingen's Avatar
That's amazing. Good to hear that you were able to extract that kind of whp safely with e85. Makes me wish we had it here in VA.
Old Aug 27, 2007 | 09:41 AM
  #249
Mirage2.0's Avatar
What your a/f ratio? I know that it suppost to be 9.7:1 at stoich.
Old Aug 28, 2007 | 09:27 PM
  #250
GoSloTurbo's Avatar
i do not know, i can find out next time im at the shop. hopefully i will be there this week to pick up my motor for my mirage
Old Sep 26, 2009 | 08:42 PM
  #251
*02Lancer*'s Avatar
hey you can update me to the list now while im N/A Im staying with the 4g93 intake i like the down low hp so im at 107.23 HP and 121.29 TQ on a dynojet with 93 intake, short ram intake, lightweight flywheel, 2.5" custom exhaust with borla muffler and dynomax highflow cat
Old Nov 15, 2009 | 10:56 AM
  #252
negrito 18's Avatar
can u guys add me 2 tha list???
Mustang Dyno:98hp n 107lb of tourqe on a 3rd gear pull with an sri
Old Dec 10, 2009 | 05:31 PM
  #253
03lances's Avatar
Well I dont know if you guys will count this or not but hey. Currently untuned (just afrs right and low timing for now) 10psi 16g turbo kit using vdr gave me 188whp and 217wtrq 3rd gear pull.
Old Dec 10, 2009 | 09:32 PM
  #254
ROCK's Avatar
Good torque numbers.
ROAD/RACE
Old Jan 7, 2010 | 06:25 PM
  #255
Boeturbolancer's Avatar
That's not bad at all... especially for an untuned setup. You'll see that number jump big time once you get afr's and your timing in check. Try to do your pull in 4th next time. Gives you a more accurate reading as it's a closer 1:1 ratio gear.
