Dyno'd lancers list
Old Sep 6, 2005 | 12:29 PM
  #106
blaze_125's Avatar
Originally Posted by rhyzin
here's how i'd break it down
2701 -> car's full weight(all fluids full), 5MT, w/AC
-50 -> 1/4 tank at 6.25 lbs per gallon in 12 gallon tank
+60 -> sound system
+32 -> dsm sunroof weight full assy with motors for comparison
+15 -> larger rims
+15 -> abs, prob weighs less
+120 -> you
2893 lbs
I'll re-dyno at 2900lbs and see what results it yells out.
Old Sep 7, 2005 | 10:37 PM
  #107
blaze_125's Avatar
So here it is. Using 2900Lbs as the total weight(same person driving, same fuel quantity, same road and yada yada yada). Looks like the other ones weren't that far off. Except maybe the 129hp Anyway... here it is:
Old Sep 14, 2005 | 08:31 PM
  #108
ROCK's Avatar
See this thread for new post!
https://www.evolutionm.net/forums/sh....php?p=2351325
I think you will like it.
ROAD/RACE
Old Oct 6, 2005 | 01:29 PM
  #109
gregivq's Avatar
And here is my dyno:
112.00 whp and 123.00 torque
With 10.5:1 pistons from RRM, SRI, FPR, not tuned HKS SAFR.
3rd gear.
Old Oct 6, 2005 | 02:08 PM
  #110
Boeturbolancer's Avatar
Damn... Look at that torque curve. It just stays up there!!
Those are some good numbers for an untuned Setup. The tale end AFR's start going a little rich. I'd try and keep everything around 12.8-13:1 as long as there is no knock.
Also get a CAI... when it gets rainy swap out for your short ram... for power and dyno stuff though a CAI will yield better results.
With proper AFR you'll jump up a little bit better numbers and stabalize the tale end hp/tq curve.
Do you have header/High flow cat or test pipe/TB/Intake Manifold?
Also what plugs you running/octane fuel?
Old Oct 6, 2005 | 02:11 PM
  #111
If you look close you can see where hp/tq start dropping due to your AFR's past 4500rpms. Possibly 5+ hp/tq being lost right there. Could be more if you have/get the above mods i asked about.
Old Oct 6, 2005 | 02:38 PM
  #112
rhyzin's Avatar
keeping a copy on the forum.
Old Oct 6, 2005 | 02:46 PM
  #113
gregivq's Avatar
I don't have any other mods than SRI and FPR.
Old Oct 6, 2005 | 02:58 PM
  #114
HobieKopek's Avatar
Am I the only one who can't see Greg's charts? *******it I really want to see it!
  #115
WADADLIG_OZ's Avatar
Thanks for adding another dyno to the group greg.
WADAD
Old Oct 6, 2005 | 03:03 PM
  #116
rhyzin's Avatar
i made an attachment on my last post. you should be able to see that. it's greg's dyno.
Old Oct 6, 2005 | 03:14 PM
  #117
gregivq's Avatar
Note that this dyno was done in the 3rd gear.
Old Oct 7, 2005 | 07:48 AM
  #118
4th would yield a little better numbers on the curve but the AFR would still be the same.
Old Oct 7, 2005 | 05:15 PM
  #119
For a long time you guys have been saying 3rd gear is a more powerful gear to dyno? How it produces higher hp and tq figures.
Which one is it?
WADAD
Old Oct 7, 2005 | 05:35 PM
  #120
rhyzin's Avatar
i would say 4th. the only reasoning i can come up with is that distance and speed play a role. you will have higher mph in 4th than 3rd.
