Dyno'd lancers list
Old Oct 7, 2005 | 05:41 PM
  #121
Boeturbolancer's Avatar
Originally Posted by WADADLIG_OZ
For a long time you guys have been saying 3rd gear is a more powerful gear to dyno? How it produces higher hp and tq figures.
Which one is it?
WADAD
On an NA car the differences are very little between 3rd and 4th usually. With forced induction the RPM ramp is much more pronounced and the torque is higher yielding so doing an FI car in different gearing other than 1:1 can yield very different results.
Old Oct 7, 2005 | 05:45 PM
  #122
Originally Posted by rhyzin
i would say 4th. the only reasoning i can come up with is that distance and speed play a role. you will have higher mph in 4th than 3rd.
4th is the 1:1 gearing and true gear all dyno's should be done in no matter what the car/truck/suv/etc.
When NA though it's not very much different unless using some super tranny that has taller gear sets to allow for higher hp controllability.
Most stock trannys don't have this huge varience... again though as you stated the rpm ramp and rotational force being applied is what's being measured. Thus for FI guys it's very important to do the pull in the 1:1 ratio for the most accuracy and true results. Lower gearing will yield higher results with them due to the hightened ramp... On an NA car the difference from pulling in 3rd to 4th may seem like a lot but it is still a nice long ramp that the dyno can accurately calculate off of.
Old Oct 7, 2005 | 06:02 PM
  #123
rhyzin's Avatar
oh yeah. i read in a dynojet instruction manual(downloadable on the web somewhere) you HAVE TO dyno in 4th. having the 1:1 ratio does make sense as the variables in finding hp are distance, time, and rpm, and if these are the main variables(i know, not all the vars) used then having your rpms at a higher range of mph will see different results. and then as boe said, accurate measure of the engine as there is no torque multiplier.
hey boe, what kind of difference have you seen between dynoing in 3rd and in 4th?
Old Oct 7, 2005 | 06:03 PM
  #124
exactly!
Old Oct 17, 2005 | 08:28 AM
  #125
blaze_125's Avatar
Originally Posted by blaze_125
I'll re-dyno at 2900lbs and see what results it yells out.
Well... looks like the weight was somewhat accurate on this one. I got on a scale this weekend and the weight of the car was 1280Kg(2821lbs) + my weight(120lbs) = 2941. I weighted the car with 1/4 tank.
I have to add my weight because it was late at night and the station was closed. So I had to get out of the car to go have a look at the computer screen
Old Jan 13, 2006 | 09:08 AM
  #126
MIA2FASLANCER's Avatar
I have RRM Short ram intake/HEaders/Piggy back/ligthweigth pulley does anyone know how many wheel hp and wheel tq i might have? someone please let me know
Old Jan 13, 2006 | 09:50 AM
  #127
blaze_125's Avatar
Don't want to be rude, but this is a thread where you post your dyno graph. Not where you ask questions You should dyno around 115-120
Old Jan 13, 2006 | 07:36 PM
  #128
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
^ +1
Once you get past the neophyte tuning mentality, you would know that there is no way to calculate how much power you will get by adding up your mods or any equasion like that. So the best answer to that question is that you will have somewhere between 100 and 120 whp and 110-130 wtq, but that's assuming you didn't get too open of a header, in which case I've actually seena loss of torque.
But seriously, the only way to tell is to pay the $75 and get it dynoed.
Old Jan 18, 2006 | 08:57 PM
  #129
blaze_125's Avatar
My latest results with piggyback:
Old Jan 18, 2006 | 09:04 PM
  #130
Moderator
Bomb Squad Unit #02
Very nice Blaze. The curve is very nice and stable, and you have a lot of torque a long way, then the max hp hits right about where you want to shift. What other mods do you have, or is that just with the piggy?
Old Jan 18, 2006 | 09:18 PM
  #131
03RallyLancer's Avatar
blaze dont forget to put type of dyno and conditions up as well... but nice pulls
Old Jan 18, 2006 | 10:38 PM
  #132
rhyzin's Avatar
are you letting it hit the rev limiter? you gotta end the run before that or you get that spike you see at the end.
Old Jan 19, 2006 | 07:10 AM
  #133
blaze_125's Avatar
Thanks. On that pull the mods were:
Sri, Kamikaze header + dp, cat-back, piggyback
That pull was done the day before I installed my bored intake manifold. Now I'm just waiting for nice weather to quantify the gains of the IM.
I'm using the Auterra Pda dyno.
Yeah I know I should stop before but I always want to see exacly what's going on... so I figured most users would know where the rev limiter kicked in.
Old Mar 10, 2006 | 06:47 AM
  #134
comatose721's Avatar
i'm getting on the dyno tomorrow. i'm so excited! i'll post my results. (right now i've got an exhaust leak and some minor odds and ends that will effect the results a little bit but hey, after all it is just a set of numbers) i'm looking to get a baseline before i boost.
Old Mar 10, 2006 | 06:56 AM
  #135
gregivq's Avatar
^Nice, can't wait.
