Need help with my engine
Old May 12, 2015 | 10:04 AM
joyboy390's Avatar
Ok so I have a 2002 Lancer ES and the engine just cut off while driving up a hill. At first I thought it was the timing belt had snapped because while driving it was losing power going up hill and made a weird sound before it stopped. But I checked the timing belt and its totally fine. It moves when you try to start the engine but it just doesnt kick on. Ive checked the spark plugs theyre fine, the gas line is good too. I just cant figure out whats going on with it. Any ideas???
Old May 12, 2015 | 01:47 PM
Ev0ikon's Avatar
Ok. Back to basic.
Did it throw any code?
Are you certain you have fuel? Injectors firings?
Have sparks?
If they checked out then go over your timing belt.
If that checked out then check if you have compression in cyl.
Old Jun 28, 2015 | 12:26 PM
ls1adam84's Avatar
What does it sound like when you try to start it? Did the engine temp rise when you were going up the hill?
Brettpeters
Oct 10, 2013 03:36 PM
djikonatx
Mar 9, 2010 08:00 PM
xxitr
12
Sep 16, 2009 04:25 PM
sharkm87
Lancer Troubleshooting
19
Oct 23, 2006 04:07 AM
Creamo3
33
Oct 1, 2006 05:28 AM
