Engine running rough
Old Jan 12, 2018 | 04:09 PM
Smac's Avatar
2003 ES, 5-speed. 224,000 mi. ‘Service Engine Soon’ read upstream and downstream o2 sensors, replaced both. Still running rough.
It idles rough and runs rough, both intermittently, up to about 2300rpm.
Thoughts?
Old Jan 12, 2018 | 04:55 PM
Smac's Avatar
Thoughts?
Also, the exhaust makes a put-put instead of a smooth, normal sound.
Old Jan 13, 2018 | 09:08 PM
DSM*BOY's Avatar
Have you tried resetting the ECU after you replaced the o2 sensors? See if another code comes up
Old Jan 15, 2018 | 11:34 AM
Smac's Avatar
New code reads ‘cylinder 2 misfire’. I know the car never had spark plugs changed...maybe time for a tuneup?
Old Jan 19, 2018 | 04:04 PM
Smac's Avatar
Pulled the old spark plugs, on the plug to the far right as you face the car from the front, there was oil on the plug and in the cylinder the plug and wire go into. There wasn’t any oil on the operating part of the plug, just the part the wire plugs into. I guess the question is where would the oil come from and how can I fix that...
Old Jan 21, 2018 | 05:19 PM
02modlanceroz's Avatar
Replace the valve cover and spark plug gaskets
Old Jan 30, 2018 | 09:49 AM
Smac's Avatar
Replaced spark plugs and valve cover gasket/o-rings, reset light. Still ran rough, albeit less so. Cleaned the MAFS, ran a little better. At this point, it’s only when at idle when completely warmed up, and going from a stop in first or second gear until about 1700rpm. Past that it’s totally fine.Also, it’s a slightly different rough from the misfire.
Old Feb 2, 2018 | 10:09 AM
Smac's Avatar
Also, I might mention that I unplugged the MAF sensor and the car ran worse, and died fairly quickly.
Old Feb 5, 2018 | 05:29 AM
You're saying that it's hesitant while pulling out? If so, I'd look into the throttle position sensor
Graphic
Jun 16, 2012 11:45 PM
AustinB768
43
Jun 8, 2012 05:24 AM
whitedemon
Jun 4, 2011 12:29 PM
Methodical4u
Nov 22, 2006 02:11 PM
