Anyone get a fuel regulator for your lancer yet?
Old Sep 8, 2002 | 01:51 AM
agsmooth84's Avatar
just wonderin if any had one and what kind of difference it makes if you have intake, headers and eexhaust, thanks
Old Sep 8, 2002 | 01:58 AM
pjal84's Avatar
You don't need an FPR for just bolt ons.
Old Sep 8, 2002 | 07:34 AM
ruipina's Avatar
Maybe I am wrong but it is my understanding that a FPR will only benefit your vehicle if you have a turbo which requires some tuning.
Old Sep 10, 2002 | 05:15 AM
bahamut's Avatar
The above 2 members are correct. W/ just basic mods like I/H/E, FPR is useless on the 4g94, unless eye candy. From the factory, it's already good enough at max hold your HP around 200 NA (really pushing the FPR and fuel pump).
Of course, there is no way basic mods will give you +50 HP right off the bat (defying the laws of physics).
Old Sep 10, 2002 | 06:47 AM
agsmooth84's Avatar
well i was just wonderin cuz i got a buddy that has one in an infinite and he said he notices a difference in **** when hes ****in with it, he still needs to get it tuned
Old Sep 10, 2002 | 06:49 AM
Pimpson's Avatar
yeah but does what he notices translate into a faster car? probably not,
Old Sep 10, 2002 | 07:32 AM
pjal84's Avatar
What kind of Infinit does your friend have? If he has a G20t with the boost raised and some other goodies then yes, he'll need an FPR...only thing I can think of at least.
Old Sep 10, 2002 | 06:05 PM
agsmooth84's Avatar
its a g20, no turbo, i beat him in a race
Old Oct 14, 2002 | 12:23 PM
LancerPimp's Avatar
if your looking for aq fuel reg contact itek@itekperformance.com they have direct bolt on fuel regs
Old Oct 15, 2002 | 09:39 AM
Mitsiman's Avatar
Actually a FPR unit can help if you use teh correct one.
RPW fits a lot of rising rate units not to increase teh fuel pressure which can be done as well although the majority of cars we leave at standard at 38 psi at idle, but for the reason that using a risign rate unit helps remove flat spots on acceleration that become evident when you do mods like I/E/Air cleaner etc.
The 2.0 lancer woudl beenfit from faster throttle response without using any more fuel simply because these units have a faster response rate of 1.7 : 1 instead of the standard 1 : 1 ratio.
RPW kits have everything from the unit, fpr guage, adapters to go straight into the fuel rail, hose clamps, hoses etc.
They are also perfect to use when you do bolt a turbo onto the car.
David Thomas
www.rpw.com.au
Old Oct 18, 2002 | 10:52 PM
iodine23's Avatar
The G20t is just the "touring" trim of the G20. I don't think G20's were ever turbo here... I at least know the newer ones aren't.
Old Feb 28, 2005 | 09:40 PM
king-of-fools's Avatar
i had the FSE rising Rate fpr installed in my LS, it made a massive difference. After i had the air intake and the exhaust done, i noticed a huge flatspot when accelerating off the line. this has been smoothed out, no flat spots now, all of the farty popping noises have gone when i gear down coming to corners or lights, i can put my foot down in any gear at any speed and the car just goes. the difference is massive. Probably like me, you think everything is fine now but when the fpr is on, you'll realise what a rough drive your car was beforehand.
Old Feb 28, 2005 | 10:13 PM
Boeturbolancer's Avatar
Hell i even have one for sale... it's a command flow regulator that i used for some NA applications. It allowed me to drop the fuel pressure slightly to improve my AFR from stock. It also made my stock regulator a 1:1 rising rate since the mod was designed for an eclipse setup. If you want it let me know.
Old Feb 28, 2005 | 10:26 PM
KillahB's Avatar
Wow... this thread was only 2 1/2 years in its grave ... lol
Old Mar 1, 2005 | 05:06 PM
Sir Lancelot's Avatar
Boe, I really would like it. What kind of gains will this allow me to get, not looking for anything spectcular, but will it help overall. And will it work with the ///RRM piggy ive got? If so, ill take it.
