4G94 = Open or Closed Deck
Old Jul 30, 2004 | 12:10 PM
livelyjay's Avatar
Question 4G94 = Open or Closed Deck?
Yay I finally have a question worthy of putting into this section.
Is the 4G94 in the US Lancer an open or closed deck design? Just wondering it's potential for overboring.
Old Jul 30, 2004 | 01:22 PM
HobieKopek's Avatar
I'm not totally clear on the definition, but I believe it's open block. If I were looking at a picture how would I know?
Regardless, the 4g94 is basically a 4g93 bored to its safe production max. There's not much room to overbore before you start hitting the coolant jackets.
Old Jul 31, 2004 | 06:00 AM
fkrzo's Avatar
If you look at the top of the block with the head off, do the top of the cylinders "float", or is it a solid peice.
Old Jul 31, 2004 | 07:17 AM
Myszkewicz's Avatar
I'd be surprised if it was open. I've never seen an open deck Mitsu block before. Seen it before on Hondas, though.
Old Jul 31, 2004 | 09:33 AM
fkrzo's Avatar
I helped build the bottom of a B16 motor the other day that had an open deck, we put a brace in.
Old Aug 2, 2004 | 07:01 AM
livelyjay's Avatar
After reading through some of the larger engine tech threads, I see that boring out the 4G94 doesn't look to be possible. I was just curious because I was thinking of going turbo, and then buying a seperate engine down the road and building it up. Looks like stock replacement forged parts are the only way to go.
Old Aug 2, 2004 | 10:56 AM
HobieKopek's Avatar
I'm still not clear on the definition...I'll keep reading up and get you a definite answer, even though you're right about overboring. Not at all likely. You won't get anywhere significantly larger than stock.
Old Aug 2, 2004 | 12:16 PM
HobieKopek's Avatar
I finally understand! Closed deck.
Old Aug 2, 2004 | 12:18 PM
livelyjay's Avatar
I thought the difference was that open deck has spaces all around the cylinders for better cooling while closed deck does not. Am I right? If not, what is the difference?
Old Aug 2, 2004 | 12:26 PM
HobieKopek's Avatar
That is correct. Though the water jacket is visible, it does not fully surround the cylinder wall at the deck. I guess that qualifies as a semi-closed deck, but it's not open.
joshua webb
Lancer Engine Management / Tuning Forums
Feb 18, 2017 12:41 PM
dspucches
Lancer Tranny/Drivetrain Tech
Oct 29, 2011 12:36 PM
INJEN///
Lancer Aftermarket Forced Induction Tech
Sep 24, 2010 12:23 AM
EvoIXMR
Jan 31, 2008 11:41 PM
94AWDcoupe
Oct 27, 2006 06:34 AM
