gauges
Old Oct 13, 2002 | 11:20 PM
03RallyLancer's Avatar
gauges
with simple bolt on... headers, intake, exhaust, test pipe, etc i wouldnt need to get any kind of gauges would i, like a air/fuel ratio or anything like that?
Old Oct 13, 2002 | 11:33 PM
trigeek37's Avatar
unless you install a lamda wideband f/a gauge - which are pretty expensive - I wouldn't bother with a f/a gauge. the lamda gauge has a probe in your downpipe or x-over pipe (I'm not sure what it is called in a non forced induction car).
you might think about doing a mechanical water and/or oil temp, or egt - can't go wrong with any of them, espically after you add more performance parts.
but, imo you would be better off saving your pennies for a turbo, wheels, coilovers etc then dropping a lot of cash on gauges.
Old Oct 13, 2002 | 11:35 PM
i was just makin sure you know i didnt need em to watch out for any problem with just simple bolt ons... by the way can u post a pic of your car i love rx7s
Old Oct 13, 2002 | 11:49 PM
trigeek37's Avatar
look in this thread... I didn't want to post them here cause I didn't want the thread to get moved...
https://www.evolutionm.net/forums/sh...532#post109532
Old Oct 14, 2002 | 01:31 AM
Braf's Avatar
RX
Nice RX.
Yeah, a wide band lambda is choice but I use a gauge attached to my stock oxygen sensor. It still gives useful if limited information. Not much help for tuning as the switching range is very short but it can identify problems. If you have concerns about running lean, than go ahead and get the gauge.
P.S. The Auto Meter gauge looks very pretty and trick.
Old Oct 14, 2002 | 04:47 AM
tikibeast's Avatar
ok, with the above listed, how much hp can we expect to pick up?
Old Oct 14, 2002 | 05:23 AM
Ayanami_OZ23's Avatar
yeah so with all the improvements with bolt ons we wouldn't need guages right???
Old Oct 14, 2002 | 05:28 AM
trigeek37's Avatar
i wouldn't think so with the mods done so far. you really can't lean out with just intake & exhaust. if you go forced induction, then it is another matter. you will probably have to worry about a/f then, which can be taken care of with a standalone cpu or ecu upgrade (I'm not familiar with the ecu of the us lancer ). at this point you need to start thinking about water & intake temp, cause turbos cause a lot of heat.
ant_turbo
E85 / Ethanol
12
Feb 23, 2018 10:50 AM
elkazX
Oct 15, 2014 03:30 AM
McDougal
Feb 22, 2012 09:49 AM
Jp7
Mar 3, 2008 10:01 PM
