Injen intake for auto
Old Oct 24, 2002 | 04:00 PM
ghostrider's Avatar
Originally posted by pinoyesv6
personally i wouldn't use that evo vent to bring cool air to the filter unless you can find a way to close the vent or something. the galant's evo style hood is the same way. but yea many people with short ram have run into problems with sucking in water...and we all know thats not good. maybe find a way of makeing the water not get sucked in hmmm
That's a concern of mine also. I've seen the topic discussed before, but I don't think any solution has been given. I did a search and Pimpson mentioned that the K&N filter uses an oil-based repellant, so that eases my mind a little bit.
Old Oct 24, 2002 | 04:19 PM
pjal84's Avatar
Pretty much anything that isn't a foam filter uses and oil based filtration screen combined with paper or gauze. This issue is really blown out of proportion. Drive with enough care and it's a non-issue even with a true CAI. As for a vent, a fine metallic mesh or like in case of the Road Race duct, simply place in front of filter. Water wouldn't get on the filter period.
Old Oct 27, 2002 | 09:18 PM
pinoyesv6's Avatar
yea a duct or some kinda screen would help out especially with the people in the northern states. snow is a big issue. with snow hydrolock isn't an issue but the snow caking over the filter and causing the enging to suffocate. even on a short ram. i've seen that in person, even without the scoop...
i've also seen hydrolock with a short ram setup even without a scoop in the hood. yea its rare but it can happen. seen it more on the cold air. o yea the aem bypass valve doesn't work on the injen...
but yea having the duct lead to the sides is best.having it lead to the front is good too but you might run into problems if the filter is open at the front too. if you really have some time, determine your car's sweet spot. each car has a different sweet spot for sucking in air. its the part that gets dirtiest the most and have the air diverted there if possible.
1 more thing, oil never mixes with water
ShanesEVO
31
Jun 5, 2013 03:40 PM
chris89
Jul 7, 2011 04:58 PM
Tommy Di Cat
14
Jul 1, 2009 11:23 PM
V8-EATER
23
Oct 9, 2007 11:27 AM
evo_will
Jul 18, 2005 03:59 PM
