Called in for a Recall
Old Oct 13, 2004 | 06:12 AM
  #31
neilschelly's Avatar
Originally Posted by timdog4life
A few questions for you guys. I have a rear sway bar, anyone think this may effect them fixing my shocks under warranty if they are bad. Should I take it off before I go?
That's questionable. Theoretically, the rear sway bar would stiffen the rear suspension allowing the rear struts to work less, because they are always working together rather than without it, when the struts may be working closer to the extremities of its motion. But at the same time, it is an adjustment to the rear suspension.
I would never recommend taking off any part to get warranty work - it's dishonest, for better or worse. But I would suggest making sure the mechanics know what they are dealing with. If they know how a sway bar works, then it should make sense that it would only serve to ease the struts' work, rather than put greater stress on them. You don't necessarily have to bring it up, but if they do, then discuss it with them until a resolution is reached.
By the way, it could be the sway bar itself doing the creaking. Have you greased between the bar and perches?
-N
Old Oct 13, 2004 | 06:24 AM
  #32
KUlancer's Avatar
Originally Posted by RobertK
who are you refering to? if it's me, I highly doubt they noted my test pipe, I wasn't in there more than 15-20 minutes.
No... its my friend ryan... its for ALL LANCERS ( 2002 - 2004 ) Evos encluded aswell as OUTLANDERS.
Actually i'd rather have my old 1 back... it felt stronger. eg. stronger a/c and air... not i have to go to 3 just to get the same amount i used to on 2... idk.. mybe its just me.
