K strut bar problem! I think i F***ed up
Old Jan 12, 2005 | 08:47 PM
SIMSSEGA's Avatar
i got it!!!!!
This was the problem
ok i looked down the hole to look at the bolt and it was off centered alittle bit. So what was happening was that i was tighining the bolt as far as i could until the walls around the srtut bar forced the wrench off the nut. So what i was doing was just gripping the top half or third of the nut and then the wrench slipped off making it feel like it was turning the nut when i really wasnt doing anything at all. So what i did was take off all the bolts and just try to get that one on that was giving me trouble. I turned it very slowly and made sure i didnt slip off the nuts and i got it on, the other three nuts went on with no problem. Man that was problem solving for the day.
Thanks for all your help guys. Gotta love evom
Old Jan 12, 2005 | 10:23 PM
MY2003OZ's Avatar
Registered User
good stuff..... I told you those damn things are hard to get perfectly on center.
Old Jan 12, 2005 | 10:48 PM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
I had the same problem, only we had to shave down one of the nuts to get it to fit inside the cup and still line up with the threads. I say "we" because I was lucky enough to be at the RRM shop when I did this. Although they have a jig, every Lancer can be off by a mm or 2, and that might make things a tight fit. But you got it, hopefully this thread will help others if they have the same dilemma.
VishnuEvo8
Jul 25, 2015 12:55 PM
deeman101
Oct 27, 2014 11:28 PM
EGbeater
Jan 31, 2014 04:00 PM
iodine23
Apr 12, 2004 08:55 PM
