Overdrive
Old Dec 28, 2002 | 10:13 PM
pearlwhiteoz's Avatar
never shift ur auto..its totally worth less...
and..
yes lancer does have O/D but u cant turn them off..its in the car all the time....its 4 speed..but once the car go over 60..u can acturally hear ur car shift again..thats the O/D gear...its not 5th gear..but its there to save u gas!!
g0tglows7icks's Avatar
well i guess then...since i dont even remember wat number is which ...i guess 3 is for a lil more power which mean that 3 has no overdrive but its not good after it reaches 60
so wat does 2 and L do?
Old Dec 28, 2002 | 10:15 PM
supaherogenius's Avatar
I'm supposed to drive on 3 if I drive less than 60? Okay. I don't know. I want to make it easier on me and just drive on D. Is that okay?
Old Dec 28, 2002 | 10:16 PM
bahamut's Avatar
Originally posted by hardcoretuner
ummm
in my auto when i race i shift from L > 2 > 3 > D
that yields better times than just the normal D and my tranny is just fine plus warrenty, so whatever
That's a misnomer.
It sounds and feels fast, but it doesn't help you. You'll shift where there is no power in the rpm band. At least, you'll lose .2 sec or more on the 1/4 mile.
As for tranny, you'll eventually screw up your slushbox. It wasn't designed to shift. Once you hit 40K in mileage, the tranny will start to thump and slip like crazy.
Old Dec 28, 2002 | 10:18 PM
L is the trans only using 1st gear,
2 is the trans only using 1st gear and 2nd gear,
3 is the trans only using 1st, 2nd and 3rd gear,
D is the trans using all 4 gears + O/D gear
Old Dec 28, 2002 | 10:20 PM
Yay! D it is!
Old Dec 28, 2002 | 10:21 PM
bahamut's Avatar
your first is correct. putting a 3, O/D will never activate.
a 2 is purely going uphill or downhilll (slow your descent speed).
L is just 1st gear and getting out of a deep mud or snow.
Old Dec 28, 2002 | 10:22 PM
bahamut's Avatar
yes. 4th is O/D for a slushbox.
If I remember my stock tranny shift pts correctly,
4th gear = +63 mph
3rd gear =
2nd gear =
1st gear =
I can't remember the rest. My car has't been stock for a very long.
Old Dec 28, 2002 | 10:30 PM
Yay! D it is!
you are correct!! leave it in D...its there for reason!!DRIVE!!!
Old Dec 28, 2002 | 10:31 PM
thanks for the knowledge guys...now i kno wat those damn numbers are
Old Dec 28, 2002 | 11:24 PM
cupOZnj's Avatar
http://www.howstuffworks.com/automatic-transmission.htm
i love that page.
please read up and learn what "gears" are, those strange and magical things that help make your car go vroom.
if you are lazy here is the basic version:
an engine can only safely rotate in a certain rpm band. most engines can operate between 600 revolutions per minute and 6000 (or more, 9000 maybe). a gear is designed to translate a small turning wheel's force to a larger turning wheel's force. if there were only one gear on a car, than the tires could only rotate with the maximum revolutions of the engine. so there are multiple gears. each gear is progressively larger, giving the range of speeds the tires can rotate at in relation to the engine a larger range. so 1st gear, the tires can rotate from 0-30 mph, in 2nd gear they can rotate from 5-60mph, 3rd they can rotate from 15-80mph, etc (i just made those up, they are not exact). your transmission selects these gears (if you are auto) for the proper speed you are driving. L-3 gears are reduction gears. overdrive, by definition, means that the output is greater than the input, which means that your car can travel at highway speeds and the engine can still stay at a lower rpm, increasing effeciency. for this you need a gear ration that is < 1:1. read up on gear ratios and how they work.
Old Dec 28, 2002 | 11:45 PM
ryancb's Avatar
warenty doesnt cover droping the clutch or manual shifting in a auto its in the warenty book somewhere.
overdrive1
Jun 2, 2017 02:58 PM
overdrive1
Nov 11, 2016 05:36 PM
overdrive1
Aug 27, 2016 09:12 AM
overdrive1
Nov 30, 2013 11:22 PM
overdrive1
Canadian Forum
Mar 2, 2011 11:50 AM
