How could I add a engine system like the movie initialD?
Guest
Posts: n/a
How your turbo wear increases with ALS depends on how much you use it. You can leave it off when not needed. When needed (hairpins etc) you can set it the way you want it, ie keep the turbo spinning at the speed you want. This will keep revs at a certain level. When you have ALS on, from inside the car it sounds like you are driving over gravel and the gravel bounces off inside the wheelarches.
A MoTeC M48 is an Australian product. It is a programmable ECU that can be programmed to generate ALS or to automize the intercooler waterspray amongst non std Evo features.
initialD
11
Dec 6, 2003 06:43 PM
