Piggyback Install ?
Old Feb 23, 2005 | 08:34 AM
N1te's Avatar
Piggyback Install ?
Do you pull the wires out of the ecu plug and weld it to the piggyback wire? Do you cut the wires and weld the piggyback wires a couple inches up from the plug so the wires still plug in? What does T-Into the wire do not sever it mean?
Old Feb 23, 2005 | 08:38 AM
Evodreamer's Avatar
Don't take a welding torch to your ECU. Try a soldering iron. Don't pull the wire out, T into it means scrap the cover off the wire and solder the PB wire to the existing wire.
Old Feb 24, 2005 | 04:52 PM
PGDlancer's Avatar
what's with all these threads about the piggy back install? I know that I'm new, but it seems like there's a lot:
https://www.evolutionm.net/forums/sh...ighlight=piggy
and most recently:
https://www.evolutionm.net/forums/sh...d.php?t=124546
I'm not trying to be mean, just wondering if the install instructions are that unclear.......
Old Feb 24, 2005 | 05:00 PM
xtreme571's Avatar
search first...there are more than enuf forums on pb install
Old Feb 24, 2005 | 05:11 PM
N1te's Avatar
2 of those posts are from me and they covered topics that weren't previously covered about the piggyback install
Old Feb 24, 2005 | 05:18 PM
PGDlancer's Avatar
Like I said, its nothing to do with the people posting. I am asking are the instructions clear or not. Just wondering, because it sounds like a great mod to do but wonder about the install
Old Feb 24, 2005 | 09:19 PM
ozrally05's Avatar
Well I found out the hard way that soldering is not the way to go with cars.... the only reason I say this is cause my dad knows a lot about cars and hes an electrician, and he told me with the cars soldering is not meant for a lot vibration and if you have problems its hard to redo... but we re did my lancer with the piggy back and use the clips they give you and crimp them good and hard and on the back where the wire sits use the solder to put down it gives the best connection as he explained to me the "cats ***". No problems so far and working great!!!
Old Feb 24, 2005 | 09:23 PM
twardnw's Avatar
ummm, don't wanna dog on your dad, but if soldering isn't that good, why is that what the factory does?
Kid Lancer 7's Avatar
so that means u cliped all the ecu wires in half??
Old Feb 24, 2005 | 09:25 PM
ozrally05's Avatar
good question lol, im not saying its bad but its caused me problems thats all....but then again i did it myself the first time so I mostly f'd it up a lil but so far so good with the way my dad told me to do it so im not complaining.
Old Feb 25, 2005 | 08:59 AM
PGDlancer's Avatar
so it's not the instructions that are the problem? just the technique?
Old Feb 25, 2005 | 01:12 PM
comatose721's Avatar
i T'd into the stock harness, soldered the pb ecu in, taped the connection, and tucked it neatly back up into the dash...my connectons are holding on there great...also another idea...if you are getting a loose connection, wait till the solder dries and then just melt another glob of solder over the previous one to make an extra stronghold for yourself...i can try and upload pics if anyone needs them but its a pretty self explanitory and makeshift way of doing it...
Old Feb 25, 2005 | 01:14 PM
twardnw's Avatar
I think I'll go home and write up a how-to on soldering for you guys, doesn't sound like it's being done correctly from these posts
Old Feb 25, 2005 | 06:53 PM
/\ /\ Please Do! at this point......anything will help!
jackevox
Apr 11, 2010 11:55 PM
RA032924
Mar 7, 2009 08:53 PM
DangerousDan
Aug 10, 2007 07:00 PM
liquidbeef
Lancer Troubleshooting
13
May 14, 2006 05:59 PM
BLiu
19
Jul 27, 2004 11:55 AM
