PDX bars came in today and.....
Old Apr 23, 2005 | 10:40 PM
  #31
twardnw's Avatar
Originally Posted by BensLancer
would you recommend these for a daily driver?
definitely, it helps the car handle much better, makes it a little more fun to drive
Originally Posted by arnold16890
I thought u only have to take out the 2 nuts, slide in the bar and tighten the nuts back as hard as u can...
that's basically it
i dont seem to be able to locate any bolt for the installation of a trunk bar on my 04 ES
you'll have to remove the carpet on the sides of your trunk to get access to these
Old Apr 24, 2005 | 11:03 AM
  #32
Blacksheepdj's Avatar
is it a good idea to have both rear sturt bar (in da trunk) and the lower tie bar? will my car be tooooo stiff? and what does "torque specs" mean? (from the installation instruction)... and one more thing, i dont seem to be able to locate any bolt for the installation of a trunk bar on my 04 ES.... and the installation sounds very risky and difficult... I thought u only have to take out the 2 nuts, slide in the bar and tighten the nuts back as hard as u can...
I don't believe the trunk bar fits in the 2nd generation Lancer. They removed those bolts.
No, you're car won't be toooooo stiff. I promise.
If you get a torque wrench, you set it to the number they give you. Then you tighten the nut until the wrench starts clicking. That means you're applied that exact amount of torque when tightening the nut, and therefore, the nut is as tight as it should be. No more, no less.
Old Apr 24, 2005 | 12:22 PM
  #33
arnold16890's Avatar
OO merci beaucoup mucho gracias
Old Apr 24, 2005 | 12:44 PM
  #34
Que?
JK
Old Apr 24, 2005 | 01:37 PM
  #35
twardnw's Avatar
ahhh, news to me, thanks
Old Apr 24, 2005 | 08:38 PM
  #36
sadude's Avatar
whats a 2nd generation lancer??? 04 and beyond
Old Apr 24, 2005 | 08:39 PM
  #37
twardnw's Avatar
I thought mirage's were the tru 1st gen lancer?
Old Apr 24, 2005 | 09:38 PM
  #38
i think 02 and 03's have the bolts for trunk bar....2nd generation means 04-05... i dont get how the trunk bar could help tho....
Old Apr 25, 2005 | 04:51 AM
  #39
sthiewes's Avatar
I'll be getting my bars in on Thursday. I will not be able to install this weekend but next weekend I will.
Old May 6, 2005 | 08:19 AM
  #40
sthiewes's Avatar
Well tomorrow is the day I install my PDX Bars. Have the instructions for the lower tie bar and Rear Strut Bar.
But is there any last minute things I need to know?
Old May 6, 2005 | 08:48 AM
  #41
Shingen's Avatar
With the rear trunk bar take your time. When you cut the carpet try to make it look as good as you can. Otherwise it will look lreally bad.
Fox
Old May 6, 2005 | 10:18 AM
  #42
Fox
I didn't cut my carpet. I just kinda slid it forward. Works fine.
Old May 6, 2005 | 10:59 AM
  #43
Shingen's Avatar
For the rear strut bar or the RS trunk bar? Cause for the rear strut you have to remove or cut the carpet.
Fox
Old May 6, 2005 | 11:11 AM
  #44
sthiewes's Avatar
Fox
I plan on going slow. I want to make sure I get a clean cut.
Old May 6, 2005 | 11:12 AM
  #45
Shingen's Avatar
If you make your cut straight up from the floor up that is the best way to do it. I just cut a huge hole in mine and it looks really bad.
Fox
