RRM strut bar fitment?
Old Apr 24, 2005 | 09:01 PM
arnold16890's Avatar
will the rrm single tube strut bar from erockoz on this forum http://gallery.enilson.com/thumbnails.php?album=7
https://www.evolutionm.net/forums/sh...5&page=1&pp=15
fit my 04 ES? need help really quick, already did a search but came up with nothing. Any help is appreciated, thanks in advance
Old Apr 24, 2005 | 09:18 PM
Evios's Avatar
As far as I've seen/heard/read, the strutbars made for the 02-03's will fit the 04-05's just fine... across all lancer models (-evo)
Old Apr 24, 2005 | 09:40 PM
awesome, thanks
Old Apr 25, 2005 | 08:59 AM
Blacksheepdj's Avatar
I say yes.
I sold my RMR strut bar to an '05 owner and he had no problem. So I'd assume this would be fine as well.
Old Apr 25, 2005 | 11:37 AM
HobieKopek's Avatar
It's all still the same chassis/suspension, correct? I'm imagine so, but I don't know enough to say with 100% certainty.
Old Apr 25, 2005 | 04:15 PM
pgmike's Avatar
mine doesnt fit my 03 well enough even. i have to force it so much that i have stripped the threads on the bolts on top of the strut
Old Apr 25, 2005 | 04:22 PM
Guru_Del's Avatar
then you needed to drill the holes out better.
had to do that to mine.
Old Apr 25, 2005 | 04:28 PM
pgmike's Avatar
what? we have to drill the holes out of the kbar more than how it came? that is somethign taht should be done at the company. i planned on doing that next time i took it off anyways.
Old Apr 25, 2005 | 04:47 PM
Marques's Avatar
Yeh my strut bar from RRM the single one had the same problem as you Mike. It would not go on at all. Me and Kareem tried everything until we figured out we had to get a rubber mallet and beat that **** up. I didn't even bother to put it on after that. I just sold it.
Old Apr 25, 2005 | 05:11 PM
pgmike's Avatar
you get anything else instead?
Old Apr 25, 2005 | 05:52 PM
Doesn't surpise me. I had to grind my RRM cubby plate down. Nobody is perfect...
Old Apr 25, 2005 | 07:05 PM
wiretap's Avatar
maybe it could be the way your car is parked too.. make sure your wheels are straight and the car is not on any sort of incline or twisted in any way.
Old Apr 25, 2005 | 07:06 PM
twardnw's Avatar
with the RRM bar I hear it's best to jack one side of the car up to get the bar on. Problem is, that's preloading the suspension. Yes it will prevent flex, but it's being forced out of 'normal' to start with
Old Apr 25, 2005 | 07:09 PM
wiretap's Avatar
oh yes, that means you would probably have to get an alignment as well.
Old Apr 25, 2005 | 07:10 PM
twardnw's Avatar
well, I don't think it's that much of a preload on it, but it's more than normal. On a semi related note, I've got the Progress Springs, RDD front, read, and tie bars, and have yet to get an aligment. My tires do not wear any different than stock either
