Torque specifications for the U.S. Lancer
Old Apr 8, 2007 | 05:34 PM
Z_Lancer_Man's Avatar
If you can set your torque wrench to 74, then do that and torque it. The +/- 7 is the "flexibility" in the actual torque applied to the nut/bolt.
Old Apr 9, 2007 | 03:57 PM
Blacksheepdj's Avatar
Set it to 74. As Z said, the +/- stuff is basically telling you it's OK to be off a little. But if you're able to set it exactly right, do that.
Old Apr 24, 2007 | 04:33 PM
MitsuOZ's Avatar
what would be the Torque setting for the hub bolt?
Old Apr 24, 2007 | 07:31 PM
You mean the big fat nut in the center of the lug nuts? For the center hub nut its 181 ± 21 ft·lb
Old May 27, 2007 | 11:38 AM
SuperStreet2K6's Avatar
Thanks for the torque specs! Incredibly helpful!
Old Jul 1, 2008 | 05:20 AM
icole's Avatar
I spent hours searching for down pipe torque on this site. I finally did a regular google search and found this. There should definitely be a sticky thread with the torque specs for common mods.
Old Nov 20, 2009 | 06:25 PM
thcomb's Avatar
bump this back up
Anybody have the torque specs for all of the caliper bolts?
Old Nov 21, 2009 | 07:19 AM
thcomb's Avatar
anybody?
Old Nov 21, 2009 | 09:06 AM
thcomb's Avatar
I think I found torque values for the slide bolts, top is 63 ft/lbs, lower is 37 ft/lbs. What about the 2 bolts that attach the calipers to their mounts?
Old Dec 17, 2009 | 01:27 PM
thcomb's Avatar
Found it, they are 74 ft-lb
Old Jan 10, 2020 | 09:25 PM
Frank Gallagher's Avatar
hate to ask but do you know the torque for the transmission pan? cant find anywhere, i have owners manual and a ****ty service manual which i paid for and downloaded but its all scattered. thanks in advance..
EvoDan2004
157
Apr 2, 2026 12:52 PM
blk-majik
Jul 20, 2015 08:18 AM
badev0
May 20, 2014 11:18 AM
CanuckLancer
18
Apr 3, 2013 07:44 AM
anthonypazsd
Jan 31, 2010 03:01 AM
