my tailight is out... and....
Old Nov 5, 2005 | 06:06 PM
akasirlancerlot's Avatar
i cant get it to come back on. ok
so heres the facts.
1) my dirvers taillight is out... not the blinker and reverse ect. but just the light for braking and lights on.
2) my gauge cluster is out, just the red on the rpm and well everything but the blinkers high beam check engine ect.
3) the fuse for the gauges is good or else the rpms and such would not be working (they work they just dont light up...)
4) everytime i replace the fuse to the taillight it blows! wtf. so everytime i put it in and turn on the lights it goes out instantly.
5) its not the bulb, i tested it.
6) nor is the bulb on the gauges, i tryed my old es clsuter same problem ect.
7) when i blew my fuse for the passenger side one.... the hvac lights wnet out, and then my (automatic) lights around the shifter (d n 1 2 3 ect) are out.
so are they linked? im inclined they are? wtf do i do at this point!
thanks for the help.
Old Nov 6, 2005 | 04:59 AM
scorp64's Avatar
Just a slightly educated guess here after a quick look at the service manual. Behind the dash, on the drivers side, is a junction block. This junction block is part of the Lancer's Simplified Wiring System and a number of the connectors work to control both dash and tail lights. Check this junction block for damaged wires and connectors.
Old Nov 6, 2005 | 09:43 AM
are u talking about the passenger cabin fuse box or a seperate "junction" box?
bump common guys.
Old Nov 6, 2005 | 09:47 AM
wd_cross's Avatar
yup... same thing happened to me. its the fuse under the hood and another fuse beside the steering column. i dunno about the blowing fuse everytime you change it part, but the same lights stopped working for me (actually the EXACT same ones) and yeah, found it was the fuse. What i also found was when i checked to see if the fuse was good or not, the reader (i used two different ones) kept telling me it was good but when i took the actual fuse out and checked the bottom part of the fuse, it was out (so basically the top isn't good enough to check). i believe it was both the 7 AMP fuses. hope that helps! if not what i did was downloaded an electrical schematic (i think i found it on here) and went through it wire by wire. good luck!
Old Nov 6, 2005 | 12:29 PM
twisty1251's Avatar
yea, same thing happened to me. there is one fuse under the hood, and if it blows all the interior lighting will go out, along with the tail light.
Old Nov 6, 2005 | 02:38 PM
scorp64's Avatar
bump common guys.
According to the service manual there is a junction box behind the gauge cluster. Several of the connections on there run to both the gauges and the tails.
You mentioned trying your stock ES cluster and still had the problem, so it's possible something is shorting a connection on that junction box.
Old Nov 6, 2005 | 06:35 PM
k thanks much guys, when u had this happen what fuses did u try to replace, both the one in the engine and passenger?
also are there fuses behind in the "junction box"
Old Nov 7, 2005 | 09:16 AM
brentg07's Avatar
hmm this is interesting, b/c I had my tail light and HVAC go out but not the gaugle cluster lights. I fixed that problem now probably 2 years later only the left half of my gauges light up, I still get lights that are not always on (if that makes sense) like the low gas light, and cruise, but the lights that just light up the background dont work.
Old Nov 7, 2005 | 12:25 PM
blaze_125's Avatar
Look for a 7.5 amp fuse in the box under the hood.
Old Nov 7, 2005 | 12:47 PM
i do but everytime i put a new one in, it goes out... wtf
Old Nov 7, 2005 | 12:58 PM
blaze_125's Avatar
Hey... that's up to you to find out... at least I was right about the fuse j/k... I have no clue what the problem could be. Have you done any electronic work in the car in the past few days... Have you installed the piggyback from Rrm... the piggy wouldn't cause the issue but you have knocked a wire while installing or something...
Old Nov 7, 2005 | 01:01 PM
rrm installed it
Old Nov 9, 2005 | 09:03 PM
05ES's Avatar
go back to them and ask then. If it only started happening aftert hey installed it then go and ask if they know what it might be. maybe they just knocked something outta place.
Old Nov 9, 2005 | 10:52 PM
vietxscapeD's Avatar
all i know is that ur shorting out somewhere ... thats why it keeps blowing with every new fuse put in. I havent had this problem.. only similar.. my left side parking lights went out and every time iput fuse it in blew. turns out some water got into my license plate lighting connector and was shorting...
Old Nov 9, 2005 | 10:56 PM
lookslikeanevo's Avatar
its a fuse pete and i would check all recently installed things with wiring/ or radio to see if its shorting anything out
