Harness bar advice
Old Mar 19, 2006 | 07:24 PM
ambystom01's Avatar
Harness bar advice
Ok I'm planning of running harnesses for autocrossing in the summer. Rather than do the usual thing of attaching them to the rear seat I was thinking of using a GSC harness bar. Would this be possible with the stock ralliart seats? I was thinking Schroth harnesses since they seem the best mix of safety, and price (can't really afford 300$ a pop of Takatas).
Old Mar 19, 2006 | 08:04 PM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
I don't know if a Schroth street belt will work with a harness bar, but there are tons of belts out there that will (for around the same price or less even). Just get a harness bar that fits in an Evo (I believe Sparco tested theirs in a Lancer and said it fits), and get a harness that's meant for roll bar mounting.
Old Mar 19, 2006 | 08:08 PM
ambystom01's Avatar
K thanks, what about using them with the ralliart seats, will that be a problem?
Old Mar 19, 2006 | 08:16 PM
Moderator
Bomb Squad Unit #02
I don't think the seats will be a problem. I can't remember the ralliart seats, but are they the type with the hole in the middle for a shoulder harness? If so you won't have any problems. If not, there is probably a way to work it into the headrest.
Old Mar 19, 2006 | 08:20 PM
ambystom01's Avatar
Yeah they have a hole in middle and a hole in the headrest (not sure which one you're referring to but I assume you mean the hole between the seat and the headrest).
Old Mar 19, 2006 | 08:23 PM
bobaab's Avatar
do u really need a harness bar? I have the Schroth 4 pt harness and I have them mounted where the seat belts are mounted in the front and back...lemme try to find the thread w/ pics i took from a while ago..
::EDIT::
https://www.evolutionm.net/forums/sh...chroth+harness
what do u know..brian was all over that thread too
Old Mar 19, 2006 | 08:28 PM
ambystom01's Avatar
I was just thinking a harness bar would be a little safer, any thoughts, cause hell if I don't need to spend 300$ I sure as hell won't.
Old Mar 19, 2006 | 08:34 PM
bobaab's Avatar
What do you mean by safer? as in accidents?
Old Mar 19, 2006 | 08:36 PM
ambystom01's Avatar
Yeah as in helps with the spinal injuries and such asociated with belts attached at too steep an angle in the rear.
Old Mar 19, 2006 | 08:37 PM
Moderator
Bomb Squad Unit #02
If you're just going to wear the harness during autocrossing, and the regular seatbalt for daily driving (recommended anyway) don't bother with the harness bar. The only advantage I can see with a harness bar is I think you can still use the rear seats while the driver is in the harness. Other than that, not really needed.
Old Mar 19, 2006 | 08:38 PM
ambystom01's Avatar
K cool, guess I won't bother with the harness bar.
Old Mar 19, 2006 | 08:39 PM
bobaab's Avatar
^ That's what I was thinking. As for the safety thing, I'm not sure, but I'm sure the Schroth belts are road legal for a reason....
::EDIT::
My english just went to *poop*
i'm not sure, but i'm sure...
Old Mar 19, 2006 | 08:42 PM
ambystom01's Avatar
Out of interest what exact harnesses are you running bobaab and how do you like them since your using them with stock style seats?
Old Mar 19, 2006 | 08:49 PM
bobaab's Avatar
For the driver's side, I'm using the Schroth Rally-X 4 point harness (discontinued now). They are much better than I expected, and glue you to your seat very well. The car will feel totally different after you're strapped in. It straps you in so tight that if the door is open when you tighten everything, you won't be able to reach it I think it's helped my success in autocrossing.
Old Mar 19, 2006 | 08:53 PM
ambystom01's Avatar
K cool sounds just like what I want.
