wow its tru!!! pully rules.....
Old Apr 24, 2006 | 09:17 AM
comatose721's Avatar
Originally Posted by PGDlancer
thanks for the respnses to my ?'s by the way. I didn't even get flamed that badly
i didn't mean to be rude sorry dude. i just thought you posted in the other thread.
you will need an impact gun rated over 600 ft-lbs of torue. otherwise, it may be deemed useless
mark
Old Apr 24, 2006 | 09:36 AM
N1te's Avatar
Originally Posted by Shingen
Ever been shocked before? Ever leave a wrench atop of your battery and conect the negitive and positive and blow a fuse or set a spark that lights your engine bay on fire and burns down the garage you are working in?
You disconnect your battery because its one of the many safety steps that keeps you from hurting your car or worse yourself. I guess it's not necessary to put blocks behind your rear tires when you have your car jacked? Or it's ok to climb under your car and change your oil with only your factory jack. Or it's alright to let Frank anywhere near your car... he forgets to bolt stuff down. But anyway, it's just a precaution. And I'm just messing around. But it's always good to think safety first.
Fox
That was just the one time!
Old Apr 24, 2006 | 09:38 AM
N1te's Avatar
ok, sorry i hadn't searched it recently.... looks like it would be in my best interest to rent/buy an impact gun. my buddies and i keep thinking it would be a good investment and i already have a compressor (nice sized, not portable). but the pulley looks like a nice mod. RRM is gonna get more of my $$$ i guess
You might want to look into this thread: https://www.evolutionm.net/forums/sh...d.php?t=196901
and this ebay auction
http://cgi.ebay.com/ebaymotors/Light...QQcmdZViewItem
And this post by Rhyzin: the 00-01 mirage share the same part number with the lancer. MD373417
Old Apr 24, 2006 | 10:18 AM
jeemybo's Avatar
Could someone tell me whether the RRM pulley is a different size than stock? I didn't realize that underdrive pulleys tend to be bigger so as to slow down the spin of the accessories. This is clearly a no-no for supercharged applications.
I apologize if the answer is somewhere obvious, but I think I have been following the threads pretty closely.
Edit: Think I found the answer. Could someone confirm whether it is the same size?
Originally Posted by impetus19
The great thing is that it dosent really underdrive at all because it is very close to the same diameter as the stock pulley but a fraction of the weight. It is probably the most effective mod b/c it dosent need to be tuned it all, just throw it on and feel the difference.
Old Apr 24, 2006 | 05:47 PM
03RallyLancer's Avatar
its a crank pully thats the ssame size... the only difference is weight
Old Apr 24, 2006 | 05:53 PM
PGDlancer's Avatar
N1te, i like cost effective, but something about buying this thing off of eBay seems a little too risky for the cost you save..... i will look into procarparts.com later though. Thanks for the info again
Old Apr 24, 2006 | 05:58 PM
Mr. AutoLS's Avatar
i hear that its a waste
Old Apr 24, 2006 | 06:44 PM
RIPP makes an overdrive pulley that works with supercharged apps...they also make a small-shaft pulley for your supercharger.
Old Apr 24, 2006 | 07:05 PM
jeemybo's Avatar
Interesting. It turns out that they only use the small shaft pulley on the lancer stage 2 (this is the one that goes on supercharger shaft itself). I still have the stock crank pulley on my car. I suspect that the overdrive crank pulley is only when you plan to up the boost. I am going to talk to them about it when I go over there on Friday. BTW their overdrive pulley is #%@%! expensive.
Old Apr 25, 2006 | 04:06 PM
jsfour's Avatar
this kinda makes me excited. I am thinking i will pick one up in a fiew weeks.
Old Apr 26, 2006 | 10:41 AM
twisty1251's Avatar
normal crank pulley is the same size, underdrive pulley is smaller
Old Apr 27, 2006 | 04:45 PM
Bonethugz357's Avatar
You don't need to disconnect the battery for the pulley installation. I had a shop do mine since I never have time to do anything with my car but drive it. It took about a week for me to notice any HP gains. I guess the ecu can teach itself.
I noticed quicker rev's right away.
Old Apr 27, 2006 | 10:17 PM
it's not about the ECU learning; it is a saftey precaution!!!
Old Apr 27, 2006 | 10:45 PM
kfos01's Avatar
Originally Posted by Blacksheepdj
Why you unplug your battery - yesterday, I was taking the fuel pump off my Camaro. The end of the wrench happened to hit the positive wire on the starter solenoid for a moment. BIG SPARK. Now, imagine what COULD have happened had I not been lucky.
What COULD have happened? I'll tell you...my springs would have to install themselves
Old Apr 28, 2006 | 09:09 AM
+1 hahahah nice job.
seriously; anytime you are working under the hood, for a period of time with any non-insulated tools, i would highly recommend disconnecting the battery for your own personal safety....it's not always about letting the ECU learn ya know.....
