Evo VIII spoiler clear coat remover in a can...
Old Jul 18, 2006 | 12:20 PM
ohio-evo's Avatar
Originally Posted by SLVROZ_03
^^^So, underneath the clear coat the CF weave is in a resin. This product will react with the resin with damaging results???
I believe so as the resin is a plastic/ synthetic. Here is the quote from the 1st post
NOTE section it reads : Do not apply on plastic or any other synthetic surfaces.
Old Jul 18, 2006 | 04:52 PM
SLVROZ_03's Avatar
^^^pt taken.
Old Jul 18, 2006 | 05:00 PM
Tristar's Avatar
Originally Posted by evo_il8
05 arent cf
Not true. 05 was the last year for all CF. 06 started the CF wing with abs plastic side pods....
Old Jul 27, 2006 | 02:05 AM
r1elkins's Avatar
test it on a small area. i think the resign will not react the same as the clear coat.
Old Jul 31, 2006 | 09:52 AM
SLVROZ_03's Avatar
Good news!!! This stuff works, and works great!!! Doesn't harm the resin/CF at all. Only thing to mention is that you MUST do this as soon as you start to see any deterioration at all in the top coat. The sun actually melted through most of the top/clear coat and even some resin on my spoiler. I could actually feel the CF weave...D@MN! Getting the 6th or 7th coats on tonight after more wet sanding. I'll post pics once I get home...
Old Aug 7, 2006 | 03:53 PM
SLVROZ_03's Avatar
Here's what you've all been waiting for... PICTURES!!!
Attached Thumbnails Evo VIII spoiler clear coat remover in a can...-pic1.jpg   Evo VIII spoiler clear coat remover in a can...-pic2.jpg   Evo VIII spoiler clear coat remover in a can...-pic3.jpg   Evo VIII spoiler clear coat remover in a can...-pic4.jpg   Evo VIII spoiler clear coat remover in a can...-pic5.jpg
Old Aug 7, 2006 | 03:54 PM
SLVROZ_03's Avatar
...and some more!!!
Attached Thumbnails Evo VIII spoiler clear coat remover in a can...-pic6.jpg   Evo VIII spoiler clear coat remover in a can...-pic7.jpg
Old Aug 7, 2006 | 03:56 PM
DRFTKNGG's Avatar
Ok so it worked. Now what. You need to spray the carbon fiber surface to protect it from the elements.
Old Aug 7, 2006 | 03:59 PM
SLVROZ_03's Avatar
First, I started with just a 50/50 look at what it used to look like verus what I just removed. Quite the difference already. But then did the entire thing and noticed how it was a little too late to save some of the resin/CF. Some of it had faded pretty badly. But after 6 clear coats, It's back to it's early day glory!!!
Horray for me and my hard work...It really paid off !
Oh, BTW...use gloves and don't get it on your arms. You'll feel the burn for reals!
Old Aug 7, 2006 | 04:01 PM
DRFTKNGG's Avatar
hit it with some 2000 grit on a block hand sander. Few rubs with some good wax to bring back the shine. Voila!
Old Aug 7, 2006 | 04:02 PM
SLVROZ_03's Avatar
Hells yeah!
Old Aug 7, 2006 | 07:55 PM
Arithmetic's Avatar
Intresting, good post.
Old Aug 8, 2006 | 09:46 AM
SLVROZ_03's Avatar
Thanks, I was hoping this would give other owners the chance to fix their similiar problems for under $15. Thought about doing a DIY How-To, but if you can read directions you can do this...
Old Aug 8, 2006 | 10:24 AM
TTP Engineering's Avatar
You are correct.
Old Aug 11, 2006 | 12:55 AM
revolt4revolver's Avatar
so what clearcoat did u paint it with? more rattle can???
edit also did u reclear the bottom too? the whole thing? did u spray the bottom with peeler?
