Evo VIII spoiler clear coat remover in a can...
Old Jul 17, 2006 | 03:15 PM
SLVROZ_03's Avatar
It Works!!**Pics page 2**Evo VIII spoiler clear coat remover in a can...
Well, came across this can the other day at good 'ol Wal-Mart. It's made by W.M. Barr & Co. Inc in Memphis, TN. It's called Klean-Strip Peeler Base Coat/Clear Coat Paint Remover. Let me note what the can says...
*Removes overspray & spills from spray guns & work areas
*Removes damaged clear coats
*Removes paint delams
Use on vehicles where the top coat paint has separated from factory-applied primer.
*Removes paint in minutes
*Spray on - blow off
*No need for sanding or razor blades
Lifts automotive clear coat and base coat w/o harming the primer
*Of course, it's flammable
Okay, now on to the part that kinda has me worried... Under the NOTE section it reads : Do not apply on plastic or any other synthetic surfaces. Reading that, does it mean that it could have an ill-effect on the carbon fiber during clear coat removal? Or should I just start with a small patch and just wait and see what happens?
...And no, this isn't selling a product I make or even represent; so don't even think about closing this thread. This could be the easiest answer to every EVO spoiler owner's dilemma, including mine. I'll post before and afters once I get this project on a roll...
BTW, for $4.50 I couldn't pass it up!
Thx
Old Jul 17, 2006 | 03:38 PM
krafty's Avatar
If you have a real Evo VIII wing the clearcoat will remove itself
Old Jul 17, 2006 | 03:39 PM
krafty's Avatar
BTW.. depending on the year.. some of the wing is ABS plastic and CF, not all CF......
Old Jul 17, 2006 | 03:42 PM
evo_il8's Avatar
05 arent cf
McDougal's Avatar
Maybe try on the underside first to see if it is going to mess anything up.
Old Jul 17, 2006 | 03:44 PM
SLVROZ_03's Avatar
^^^I'd thought of that too...
I'd just spray the world's crappest clear coat off the top of the CF, nothing else. Everything else is holding up fine... Any opinions on whether it'd damage the CF or not??? It's off a 2003 Evo BTW.
Old Jul 17, 2006 | 03:45 PM
ray3328's Avatar
lol... I can attest to that
Old Jul 17, 2006 | 03:48 PM
SLVROZ_03's Avatar
Here are a couple links to what I'm talking about...
http://www.kleanstripauto.com/products/removers.html
http://www.spraykings.com/product.ph...d203f92885232d
Old Jul 17, 2006 | 03:50 PM
krafty's Avatar
Let us know if it works... I can use it on my Seibon CF hood... 1/2 the clearcoat is already gone....
Old Jul 17, 2006 | 03:51 PM
SLVROZ_03's Avatar
^^^d@mn.
Old Jul 17, 2006 | 08:19 PM
OZrallyMatty's Avatar
From: addison, not to be confused with aurora, illinois
dont do it! if the wing is abs plastic that stuff will melt it, it happened to me on my moped.
Old Jul 18, 2006 | 09:59 AM
SLVROZ_03's Avatar
^^^Again, it's the 2003 OEM CF center section Evo VIII spoiler and I'd only use it on the very top of the spoiler where all the cracking and peeling is happening...
Old Jul 18, 2006 | 11:40 AM
ohio-evo's Avatar
the cf is in a resin this product would most likely have an ill affect on the resin. If you have an 03 wing the entire wing including the side post are all cf. try this at your own risk. But be ready to buy a new wing.
Old Jul 18, 2006 | 12:12 PM
SLVROZ_03's Avatar
^^^So, underneath the clear coat the CF weave is in a resin. This product will react with the resin with damaging results???
Old Jul 18, 2006 | 12:15 PM
Spec'd's Avatar
