Help Bosch +4's
Old Sep 27, 2006 | 11:51 AM
  #31
rhyzin's Avatar
waste-spark, not wastegate spark. it's the type of ignition system we have. 2 sparkplugs per coil. iridium, double platinum, or copper core are alright. V-tip NGK's ftw.
www.sparkplugs.com
Old Sep 27, 2006 | 01:37 PM
  #32
ambystom01's Avatar
Don't bother with iridium or platinum, just get what is stock. Back when I was young and dumb I went with iridiums. I ended up paying something like 80$ for the plugs and they didn't last any longer or help my idle any more than 30$ stock plugs. Save your money and go with stock, you'll feel less like a rape victim that way.
Old Sep 27, 2006 | 01:46 PM
  #33
ambystom01's Avatar
Originally Posted by bobaab
To all those who think he wants performance gains from spark plugs: That's not what he asked. He wants a remedy to fix his idling problem. Read carefully. I'm shocked to see it come out of you amby!
My Lancer actually came with the NGK iridiums and they ran perfect..that should tell you something.
Yeah I know, I'm just tired of all these new threads by noobs that ask about the best spark plugs, engine swaps, gay sex, etc..
Old Sep 27, 2006 | 01:53 PM
  #34
rhyzin's Avatar
you really won't want better/different plugs until you're either boosted, upped the compression, or running nitrous.
Old Sep 27, 2006 | 02:53 PM
  #35
superfly78209's Avatar
alright, so if platinums dont last any longer i guess ill go w/the stock ones. i guess i could go for the coppers. they prob arent expensive. im doing intake so that prob wont make a diff. i just hate these bosches. i took off a plug wire and this white smoke came out. is that normal? my valve cover is really hot. My temp sensor is normal though. so i dunno whats goin on.
Old Sep 27, 2006 | 03:54 PM
  #36
ambystom01's Avatar
The valve cover should be hot, not sure about the white smoke though.
Old Sep 27, 2006 | 04:08 PM
  #37
rhyzin's Avatar
clean your sparkplug seats.
Old Sep 27, 2006 | 04:28 PM
  #38
Hey
thx guys. will those ngk platinums add more heat than stock ngks? or be more efficient. I want as low heat as possible after dealing w/these bosches.
Old Sep 27, 2006 | 04:33 PM
  #39
ambystom01's Avatar
The plugs will do nothing for heat, all they do is provide the spark.
Old Sep 27, 2006 | 05:11 PM
  #40
rhyzin's Avatar
if you want to do some homework, check out the sparkplug manufactuers model code sheet. colder plugs will conduct heat better and lower combustion temperatures but may extinguish the flame some and/or cause fouling of the plugs. 10:1 though, stock is all you need. if you're not boosting or modified in such a way, don't fool yourself into thinking you need different plugs.
Old Sep 27, 2006 | 09:37 PM
  #41
hey
if the plugs do nothing for heat than how come a lot of the +4's supposedly melt to the head.
Old Sep 27, 2006 | 09:56 PM
  #42
ambystom01's Avatar
Because +4s are crap. If you're relying on spark plugs to solve your temperature woes (which I don't think are a problem) you'll find yourself surprised very quickly.
Old Sep 27, 2006 | 10:13 PM
  #43
Evo666's Avatar
any Bosch sucks, stick with NGK.
Old Sep 28, 2006 | 10:26 AM
  #44
Blacksheepdj's Avatar
Originally Posted by superfly78209
LOL I never said there was going to be a performance DIFFERENCE IN MY CAR I DONT CARE ABOUT 1 OR 2hp OR ANY AT ALL. I WANT PLUGS THAT WILL LAST FOR MORE THAN 30,000 MILES THAT'S WHY I ASKED. MY BOSCH +4'S ARENT WORKING WELL SO I ASKED WHAT OTHER BRAND WOULD YOU RECOMMEND THAT ARE PLATINUM OR EVEN IRIDIUM. I DON'T MIND STOCK PLUGS BUT I WOULD RATHER PAY 5 BUCKS MORE AND GET SOME PLUGS THAT WILL LAST LONGER. THIS ISN'T ASKNG WHICH DYNOS BETTER. STOP ASSUMING AND JUDGING. lol im not angry I put caps on so you all would understand what im saying. Thanks
Bottom line - if all you want is plugs that'll last longer than 30k, you're a moron.
You're supposed to change your plugs every 15k. It's not that hard. It takes 10 minutes, and you can get a set of decent plugs for under $10. Not a bad investment to keep your car running well...
Old Sep 28, 2006 | 10:30 AM
  #45
bobaab's Avatar
understandable, keep up the the pwnage...i mean constructive criticism.
