How to Reduce Cabin Noise.
Old Dec 21, 2006 | 11:21 PM
DELANCER's Avatar
Post How to Reduce Cabin Noise.
How would it be possible to reduce the Cabin Noise when driving is there some type of material to install in the doors or maybe get a certain brand of rubber molding that would seal air and noise out better?
Old Dec 22, 2006 | 01:11 AM
omarv6's Avatar
the cheapest and lightest way would be using ear plugs !
just kidding bro .... do u realy want the waight of the sound isolater , it isnt a light mod if u wana ask me . my friend did it on a WRX STi it reduced the Cabin Noise alot but added about 30 pounds !
Old Dec 22, 2006 | 07:17 AM
SLVROZ_03's Avatar
Any sound dampening material audio-heads use for their systems would work. Dynamat, Fatmat, etc...
Old Dec 22, 2006 | 09:53 AM
DELANCER's Avatar
Yes I want to do it, I hate the shaking and annoying *** hondas around with the corny *** tin can mufflers, any of idea of a shop that does it in the NJ area?
Old Dec 22, 2006 | 11:31 AM
bruce988jl's Avatar
any audio shop will probably sell it, installing is the $$. I hear about people going cheap and using spray on roofing tar or something like that... Personally i need to fill my window buttons because they're going to be driving me insance soon with their little rattles...
Old Dec 22, 2006 | 03:08 PM
Walkingchaos's Avatar
Im using eDead for my trunk and doors to try and kill some noise. Its by far the cheapest. Check ebay
Old Dec 23, 2006 | 10:27 PM
DELANCER's Avatar
Yea thats another thing that bothers me after putting in my system the speakers rattle the crap out of the doors and switches, so you say just cut up some of tat stuff and stick it in the door? That will do the job?
Old Dec 24, 2006 | 07:43 AM
for the doors your best bet is to pay a shop, doors are a pain in the *** to properly do. The trunk is pretty easy, you just pull the matting out clean the metal surface and roll the stuff on. With the doors you have to get the door skin off then cut pieces to fit all the holes and places where wires and cables go through. But ya more or less you remove the door panel and apply the stuff to the metal frame behind.
Old Dec 27, 2006 | 06:07 PM
DELANCER's Avatar
Has anybody done this to their car? If you did do you have pics, or a guide of what you did step by step?
Old Dec 27, 2006 | 09:10 PM
kott_tot's Avatar
ive done it to the front doors and took a picture, i originally thought of getting rid of all the plastic weather protectant stuff, but decided to put it back on after i was all done. Ill go find my pictures.
my question has anyone done it to the rear deck, i know many people have subs so they dont want to block that, but i dont plan on putting one, is it easy to take that rear deck out?
Old Dec 27, 2006 | 11:39 PM
kott_tot's Avatar
i dont know if i did it right, but i took off all or as much of that black gunk as i could, after i took off the semiclear weatherstripping, then i cut strips to fit what i needed. i dont know if it is better as one big piece and i wasnt sure if i was supposed to line the actual door panel, but i could hear and feel the difference. Its nothing drastic, but it made me happy, and definitely buy the dynamat off ebay, if you go to an actual store ( i saw the door kit of extreme for $95 at best buy) it will be a lot more.
Old Dec 27, 2006 | 11:46 PM
kott_tot's Avatar
oh and for those little clips that hold the wires, take them off one at a time, roll the dyanamt ( i recommend a blunt handle to a screwdriver or something like that), poke a small hole in the metal sheet, push the clip in and the dyanamt almost acts like glue keeping those clips in, youll understand what i mean when you start putting them in. I also covered up a few holes that didnt go to anything, i remember there was a lot of them
Old Dec 28, 2006 | 04:53 AM
bahamut's Avatar
The most effective way = when you buy replacement tires, check out Tire Rack on its survey for quietness.
stock tires = loud as so with kuhmo
Just like jacked up trucks w/ swamper tires . . . they will never cut their road noise down.
krisdlm
Mar 21, 2016 04:43 PM
nixx1985
Lancer Engine Management / Tuning Forums
Oct 30, 2012 06:53 PM
crayonshinchan
Apr 22, 2008 05:24 PM
Derek888
Sep 12, 2005 04:28 PM
jdoc7
Jul 25, 2005 12:57 PM
