Max power on stock internals?(and other questions)
Old Mar 14, 2002 | 01:06 AM
phatmonky's Avatar
Sorry if I've missed this post, but a search brought up max boost over and over, but not max power.
What is the appproximate threshold of the stock internals?
What is the weak point?
Are headstuds needed to hold more boost, or will the internals fail before they are needed?
What kind of max power has been seen on street driven EVO's that are NOT using a stroker kit? Obviously a race built car, where reliabilty is not a factor, would make the most, but what has been seen on the streets?
Any links for some cars so I can view the setups of high power EVO's?
Thanks guys
Old Mar 14, 2002 | 07:12 PM
phatmonky's Avatar
Originally posted by Claudius
Usually people keep the held boost down to 1.4 bars, peaking to 1.5 - 1.6.
I realize this, but obviously different turbos are going to deliver a different amount of power, so what does that equate to in power levels? What can the internals handle? What fails?
Old Mar 14, 2002 | 08:18 PM
snelson's Avatar
It is not just a power thing but how you get the power that determines what your engine will take. High bhp and low torque is not a problem, but torque can cause issues. From what I understand, put on a bigger turbo with lower boost will not stress the engine as much as a smaller turbo at higher boost. I wouldn't run more boost than Claudius mentions on standard internals.
In the UK there is at least 1 person getting over 380 bhp from standard internals. However, as a rule of thumb most people believe that to play safe, anything over about 360bhp warrants changing the internals. However, if your torque gets close to matching the bhp, you are probably running a risk if you go much over 350-60 ft/lbs of torque.
Luckily, not many have taken their engines to the point of destruction so it is hard to know for sure.
Old Mar 14, 2002 | 09:43 PM
phatmonky's Avatar
Thanks.
Lucky for them, not for the rest of us
kika747
Oct 1, 2014 02:09 AM
extremier
36
Apr 30, 2012 12:46 PM
FastMD4G63Drive
14
Sep 30, 2008 07:26 AM
tephra
Jun 5, 2008 10:49 AM
JohnT
19
Mar 18, 2004 09:28 AM
