Great, I broke something...
Old Apr 28, 2007 | 03:10 PM
dewood*'s Avatar
I was trying to take the headliner out so I could paint it black and was stuck on the light thing thats in the center, I tried to pry it out with a flathead screwdriver and it wouldn't come out, so I kept trying and then snap there was a spark, wtf. My cd player went dead, the clock stopped working, and my mileage for the day went back to 0. I tried unscrewing the wire to the battery for 15 seconds but that didn't seem to help. Another thing this affected is when the car is off, all the doors wont lock or unlock from the inside or outside of the car unless the car is in On or started.
Someone pls help, I can't afford to have a major problem
Could it be a spark plug or something?
Old Apr 28, 2007 | 03:16 PM
mitsuozboi's Avatar
Ummm. Did you check all the fuses? Sounds to me like you shorted it out (why it sparked). Which caused a fuse to blow.
Old Apr 28, 2007 | 03:22 PM
lucentex's Avatar
Um... fuses check fuses buddy the ones under dash and ones outside in engine compartment.... and Spark plug??! Um No Spark Plugs Seem Fine From Here, Has Almost nothing to do with what you just did.....haha
Old Apr 28, 2007 | 03:36 PM
Newfoundlancer's Avatar
^ Definitely fuses.
Old Apr 28, 2007 | 03:56 PM
dewood*'s Avatar
i meant fuses, cmon you knew that lol
i just checked them and they look fine
Old Apr 28, 2007 | 04:14 PM
evodreamer01's Avatar
why dont you try replacing the fuse w/ a good fuse that works to make sure its not the fuse
Old Apr 28, 2007 | 04:59 PM
dewood*'s Avatar
I don't know what fuse to replace, the door locks, cd player, dome light all do not work
Also it says like Dome Light - 15A there are more than one 15 which one is which?
Old Apr 28, 2007 | 05:00 PM
mitsuozboi's Avatar
look on the bottom of the fuse box cover. its probably something like accesories or something.
Old Apr 28, 2007 | 05:03 PM
eehjay's Avatar
they look fine or they are fine? you need to pull them out and check them all carefully. just buy a pack of fuses from walmart or something and start troubleshooting what fuse can be a problem. thats the only thing that could have possibly happened.
Old Apr 28, 2007 | 05:07 PM
mitsuozboi's Avatar
exactly. You should be able to see the break. especially if it sparked like it did.
Old Apr 28, 2007 | 05:14 PM
lancerman360's Avatar
Every once in a while my cd player, clock, dome light, and locks will not work. But after a while it will all come back on. All my fuses are good and I dont know what causes it. It only happens maybe once a month, but it is annoying.
Old Apr 28, 2007 | 06:45 PM
lncrphish's Avatar
check the fuse box under dash and in engine compartment. (like they said) Also check the wires that you jacked up in the dome light. you may have nicked a wire and it may be coming in contact with something.
Old Apr 28, 2007 | 08:49 PM
dewood*'s Avatar
^ thats what i was thinking, but i couldn't get the darn thing off
fullm00nevo
Jul 31, 2015 10:47 PM
antwon6420
20
Sep 14, 2013 07:54 AM
Sideck
Jun 14, 2011 08:52 AM
ohthree
Aug 11, 2008 06:17 PM
EVOONYOASS
AEM EMS
Oct 1, 2006 02:18 AM
