So Much To Fix........!!!!!
Old Jun 15, 2007 | 10:00 PM
EdT's Avatar
EdT
Originally Posted by Walkingchaos
I JUST did a PCV valve myself its $3.29 and install was 7 minutes most of which was finding it.
So where is the PCV located ? show us a photo
Old Jun 16, 2007 | 01:32 AM
CamShaft's Avatar
Thumbs up
Originally Posted by escodotcarter
so as u may know i just went to fix my car because i was getting CEL code p0421 and they replaced the cat under recall. when they bring my car out after they do the work the guy shows me a list of everything else that he found wrong with the car...!!! this thing was longer then a little kids christmas list lol.
Front end links...202.34
L/S outer tie rod end...184.60
Alignment...89.95
Rear struts blown...537.18
Rear brake adjustment...59.95
Brake fluid flush...99.95
Transmission fluid flush...199.95
Fuel Injection flush...129.95
30,000 mile service...499.95
PCV Valve...45.00
Total= 2048.82 plus tax
Grand Total= 2220.41
First off I would get a second opinion....I am a mechanic and there are always second opinions....when you see a doctor do you trust him or get a second opinion, same thing.
1. Are the really that worn?
2. Tie rods, probably very little movement. Its not going to fall off...give it another 5 years(checking in between). All depends if its really that bad. To check, get a friend to wiggle the steering wheel back and forth with enough force to put stress on the linkage. Then fell and look at movement. There should be very little movement b/w parts or none at all, anything more is a call for thinking about replacing it soon.
3. Alignment, on if you do replace the steering components or are noticing uneven tire wear or pulling or steering wheel centering.
4. Struts, take a look, are they leaking, if you push down on the rear end of the car does it bounce, and keep bouncing? if yes then its time to replace, if they still have their spring damping resistance then they are still ok for another while.
5. Rear brake adjustment??? I could only think of this if your car has rear drum brakes, if so, then get a hanyes manual or ask a mechanic how to do it...and be sure you adjust them evenly.
6. Brake fluid flush...depends on how dirty the fluid is?? I like to keep it clean, I have a vacuum bleeder which attaches onto the bleeder screw on each wheel and sucks the fluid out. The old fashioned way its to get two people and bleed the brakes by cracking the bleeder and pushing the pedal all the way to the floor and holding, then closing the bleeder and pedal up again 6 or 7 times per wheel while making sure the master cylinder is full... This takes approx 1-2L of brake fluid.
7. Trans flush....if an auto, always a good idea to preserve the transmission for years to come.
8. Flue injection flush....not really a flush. More of a cleaning, and it does a way better job than that crap you pour into the fuel tank! Yes its crap... But if you keep your fuel filter changes on the regular, then no worries unless you are around 100,00 miles or so and haven't keeps up with servicing much.
9. 30,000 mile service....what actually included? Just a tune up tire rotation and fluid check?? I should hope they throw in a supermodel! Thats pricey! Just find out what needs to be done and I am sure you can do it yourself!
10. PCV valve, cheap....its not necessary but if you car has hi hydrocarbons in a driving test (if you have emissions testing) then you need to replace the pcv valve...its an emissions thing...
Old Jun 16, 2007 | 06:25 AM
Blacksheepdj's Avatar
Pop your hood. Look at the valve cover. The PCV is the thing near the middle of the valve cover. Pull off the hose that goes to the IM. It's really hard to miss...
kyoo
116
Mar 8, 2020 12:08 PM
jheff
Aug 18, 2017 08:53 AM
deanob
Canadian
Aug 2, 2016 12:34 PM
Bmurray
13
Apr 3, 2015 08:11 AM
