how much would they charge....
Old Jul 8, 2007 | 01:29 PM
lytleflo's Avatar
...to install high compression pistons??? or would it be best to do it yourself???
Old Jul 8, 2007 | 01:55 PM
ambystom01's Avatar
Why don't you call them and ask? It's silly to ask a forum what other people will charge for motor work. It's like asking how much a plate of lasagna costs.
Old Jul 8, 2007 | 03:00 PM
B-SR's Avatar
It won't be cheap.
Old Jul 8, 2007 | 03:34 PM
lancer2show's Avatar
labor around here is about 2000 dollars.
Old Jul 8, 2007 | 09:34 PM
lytleflo's Avatar
so im jus' better off doing it my self right??? so when i take my engine apart should i change anything else???
Old Jul 8, 2007 | 09:36 PM
ambystom01's Avatar
If you know what you're doing yes, but since you started this thread you don't know what you're doing therefore you should pay someone to do it for you. Mess it up and kiss your engine goodbye.
petey pab's Avatar
all new gaskets are a given.
Old Jul 8, 2007 | 09:40 PM
usually for pistons you need a machine shop.
Old Jul 8, 2007 | 09:50 PM
petey pab's Avatar
why a machine shop? just need a hone and a press. no machining required.
Old Jul 9, 2007 | 07:31 AM
atilla's Avatar
are the pistons the same diameter? you probably won't need any one to do any boring if they are the exact same diameter.
you could always pick up a second engine and use it for parts so your car isn't out of order the entire time, this way when you're ready you can just swap the engines and be done with it.
Old Jul 9, 2007 | 05:12 PM
petey pab's Avatar
^^^exactly what im in the middle of at the moment. a HUGE help.
