Fuse problems!
Old Aug 17, 2007 | 06:28 PM
BennettOZ's Avatar
Fuse problems!
So i was taking out my CD player to put a different one in and some how I managed to blow a fuse, maybe two..... Well I can see that the fuse under the hood for the stereo is blown but cant seem to get it out. Its in a yellow square plastic device that is holding another fuse, manual says that fuse controls the dome light (which also doesnt work).
How do I get these fuses out to replace them, they seem to be held in with little plastic teeth or spacers. ?????
I checked the fuses under the dash as well, but seems that there is no fuse under the dash for the stereo its blocked off so a fuse doesnt fit.
my door locks dont work either unless the car is on
Are all these problems associated to the single 10amp blown fuse that controls the stereo?
Anyways, if someone could give me an idea on how to get the fuses replaced that would be great, I have tried several things to put in there to space them out but they dont seem to budge.
Thanks,
Jared
Old Aug 18, 2007 | 02:41 AM
tonyevo123's Avatar
lol it also blew ur door locks to right ??
it come out man just give it a pull when u get it out leave that crap out that what I need no problems here
Old Aug 18, 2007 | 06:42 AM
Blacksheepdj's Avatar
Use a fuse puller? Why can't you get it out? Just not pulling hard enough or what?
I don't have your year car, so I can't look to compare, but generally fuse removal is easy. Just pull...
Old Aug 18, 2007 | 10:02 AM
BennettOZ's Avatar
Well its not that easy.... got the fuse unit out, but they are incased in a yellow device that holds them together. ??????
Here is a picture.....
Old Aug 18, 2007 | 10:15 AM
Can't you just remove the fuse from the yellow case? I can't tell from the pics if there's attached in there somehow...
Old Aug 18, 2007 | 10:26 AM
SLVROZ_03's Avatar
Take needle-nose pliers and pry apart the small yellow part of the casing held on top of the fuse. Basically spread it apart from the fuse and pull it out.
BTW, I'm out sure you had to take out the entire yellow assembly there.
Old Aug 18, 2007 | 11:08 AM
theCybe's Avatar
Is that red 8ga hanging out of your fusebox for your amplifier?
If so, get it the hell out of there. It's very unsafe. The wire that leads to whatever that's connected to in the fusebox can't handle the amount of juice it takes to run whatever you're using that 8awg for.
Run a 4awg direct from the battery instead.
And you probably blew a fuse because you have exposed 12v+ touching your chassis -- which is a ground. Which is a short circuit.
Old Aug 18, 2007 | 12:00 PM
BennettOZ's Avatar
Fixed fuse problem
I got the fuse replaced and everything works again.
Power to amp:
It does go straight to the battery. Its just not hooked up. I have been working on my system for the past few days. I know it needs to run to the battery. The other end is not hooked up to the amp either.
Old Aug 18, 2007 | 12:09 PM
Green_Bandit's Avatar
Yeah, that little yellow fuse case is a pain in the butt.
Old Aug 19, 2007 | 12:49 AM
tonyevo123's Avatar
ur welcome lol
Old Dec 17, 2007 | 03:39 AM
gohdunlam's Avatar
sorry to bring this back from the dead, but i just blew the same fuse,
could someone upload a picture of which fuse and where it is located?
thanks
Old Dec 17, 2007 | 01:46 PM
SLVROZ_03's Avatar
^Assuming the Evo has the same fuse box in the same area with the same fuses...just open it up, there's a bright yellow area that incases two fuses in it. Pull up on the yellow casing. Then pryout the fuse (I forget the amperage) with neddle-nose pliers.
Old Dec 19, 2007 | 02:16 AM
gohdunlam's Avatar
is it this one? how do i replace it? the fuse are stuck in there?
thanks
Old Dec 19, 2007 | 02:38 AM
andyktlee's Avatar
Pocket Mo
You could either use needle nose pliers to pull or a long screwdriver to push.
Old Dec 19, 2007 | 03:15 AM
gohdunlam's Avatar
buts its like reallllly secured...or its possible?
Cody Parrott
Lancer Troubleshooting
Jul 10, 2024 08:41 AM
dmik
12
Nov 20, 2021 09:12 PM
Poltergeist
Aug 15, 2015 07:53 PM
jsdragonsoul333
Jan 31, 2011 08:53 PM
wmcorcor
Jun 3, 2009 09:58 AM
