engine bay pics of throttle cable
Old Jul 21, 2008 | 08:36 AM
EvoIXMR's Avatar
Hello - I need some assistance
Did they make any lancers without cruise and if so, does anyone have a picture of their engine bay that shows the throttle cable well as to how its routed...
The Evo's have an absurdly long throttle cable and I was wondering if non-cruise lancers had these in a diff (aka shorter)lenght, but run similar enough to the Evo so I can try and see if it works.
Thanks!
Old Jul 21, 2008 | 09:45 AM
ambystom01's Avatar
let me see if I can find you a pic.
Old Jul 21, 2008 | 09:47 AM
Curt@MrLed's Avatar
Former Vendor
Why not just reroute it under the strut bar. A shorter cable may not help you if this is your plan. Not sure why your doing this.
Old Jul 21, 2008 | 09:51 AM
EvoIXMR's Avatar
I have heard re-routing it causes binding. I was just trying to clean up the bay and run a shorter cable, thats all!
Old Jul 21, 2008 | 09:52 AM
bcollinstex's Avatar
I don't think they ever made one without cruise.
Also, the throttle cable wraps around the engine and mounts up to the TB. There's part of the cruise control sitting on top of that (don't know what the piece is called).
You'll see that when someone posts a picture.
Old Jul 21, 2008 | 09:56 AM
ambystom01's Avatar
Mine didn't have cruise, AC or power anything.
Here's a picture of a rerouted line. You can see that rather than have the line go over the valve cover and then back to the firewall, it goes back to the firewall immediately. I did it to actually help with a binding issue.
Old Jul 21, 2008 | 10:03 AM
Lumpy's Avatar
The ES's didn't have cruise control, here is a pic of my engine bay.
Old Jul 21, 2008 | 10:48 AM
EvoIXMR's Avatar
amby - Is yours and Lumpy's the same - your cable seems shorter, unless you have it tucked or something....
Old Jul 21, 2008 | 10:58 AM
ambystom01's Avatar
I tucked mine because I was having an issue with the cable getting too close to the valve cover and melting slightly.
Old Jul 21, 2008 | 11:01 AM
Curt@MrLed's Avatar
Former Vendor
It doesnt cause binding, not sure where you heard that. I have switched more of these than I can count since 03. Including my 2 evo's.
Old Jul 21, 2008 | 12:13 PM
EvoIXMR's Avatar
Actually, I found it searching, farmer. I was just hoping the regular lancer would have a smaller cable, but no luck
polish_pounder
Jun 3, 2019 11:21 PM
Thahomeboyb
Lancer Engine Tech
Jun 14, 2014 06:43 AM
jwick76
Lancer Engine Management / Tuning Forums
52
Nov 20, 2011 11:35 PM
devyn339
Jul 23, 2011 09:54 AM
Blue Evo 8
Aug 10, 2007 06:51 AM
