Need a little help with a guage
Old Aug 20, 2008 | 11:30 PM
Green_Bandit's Avatar
Question Need a little help with a guage
Long story short I'm looking into getting an oil pressure guage for obvious reasons. My issue is, where people usually put the sender for the guage (the spot right above the oil filter) is used already for my oil feed. So if I put the sender there then no oil feed. Catch where I'm going? I've never heard of a "T" for it either so I'm kind of stuck.
I've searched around for a bit and using the one on the block is a no-no. So now what? The only other option I've seen is the Greddy block adapter which I hear gives two openings but I'm not understanding how that works. (I'm guessing it goes on the block but where and how?)
Suggestions? Tips? Answers?
Anything will help
Thanks!
Old Aug 21, 2008 | 06:37 AM
ThunderOZ's Avatar
well I bought a sandwich adapter from prosport. It sits between the oil pan and you filter and has for ports to tap into. I'm using one for oil pressure, one for oil temp and the third will be for the turbo oil feed line
Old Aug 21, 2008 | 10:25 AM
Nice! I would assume that the sandwich adapter that they sell and the pressure sensor that they sell are a perfect fit right?
I was getting Prosport gages in the first place and I'm just trying to get everything lined up.
BTW...mind telling me how much that sandwich adapter was?
Old Nov 10, 2008 | 11:38 AM
Neuspeed06's Avatar
That adapter leaks, and I have not figured out why since it is tight in place!!??
Old Nov 10, 2008 | 11:43 AM
ambystom01's Avatar
The best place to mount it is directly on the block. I'm not sure where this can be done on a lancer though.
Old Nov 10, 2008 | 12:16 PM
lancer2show's Avatar
i have an adapter and it hasnt leak. if you want to mount it on the block its the big hex bolt on top of the oil filter.
Old Nov 10, 2008 | 10:26 PM
Wait...Is anyone elses leaking? I'm going to put in on this weekend and don't want to end up with any surprizes...
Old Nov 10, 2008 | 10:36 PM
ThunderOZ's Avatar
it does a little. Did you use Teflon tape?
Old Nov 11, 2008 | 11:53 AM
Neuspeed06's Avatar
Yep, my adapter plate leaks also... Kinda dissapointing.
Old Nov 11, 2008 | 12:13 PM
SUNAVA BALLZ! Is it leaking around the rubber seal or where the little bolts go in? I read you're supposed to teflon tape every bolt and sender but if its leaking around the rubber seal that's no good.
Old Nov 11, 2008 | 06:21 PM
ya it does leak around the bolts..i found that out when i started the car...haha.
i teflon taped that.
Old Nov 11, 2008 | 06:28 PM
evoguy69's Avatar
gauge help
there is a plug beside the oil cooler lines i removed it and put in a t fitting and installed the senders to my defi blue racer oil press and oil temp with no leaks.
Old Nov 11, 2008 | 06:29 PM
ThunderOZ's Avatar
Yea mine is just around the bolts.
Old Nov 11, 2008 | 06:42 PM
4g94T's Avatar
i bought a tee from home depot and put it at the spot above the oil filter where the oil feed line for the turbo is at. no leaks
Biggy VIII
Aug 9, 2016 03:06 PM
fjm9898
Dec 24, 2013 06:13 PM
the1tonton
Jan 30, 2013 06:56 AM
jeffbum
Dec 3, 2007 11:45 AM
feldguy
Apr 18, 2004 02:18 PM
