E85
Old Sep 17, 2008 | 09:53 AM
Green_Bandit's Avatar
E85
I have a few questions about E85...
From what I understand it's pretty much the same as if not methanol. (From what i was told)
Sooo...would it be safe to run a mix of E85 and premium like 50/50?
What about for boosted applications?
Asking because here in the south gas shot up close to $5.00 a gallon and E85 is about $3.80 so any kind of padding to the tank would help a lot.
Thanks!
Old Sep 18, 2008 | 07:43 AM
bcollinstex's Avatar
I've heard you will need an upgraded fuel pump. Possibly different injectors.
And most importantly, you need to have your car tuned.
Old Sep 18, 2008 | 08:48 AM
nunyas's Avatar
E85 is NOT the same as Methanol.... E85 is 85% ETHANOL
Ethanol and Methanol are NOT the same thing.
Old Sep 18, 2008 | 12:04 PM
drucea's Avatar
I was told by an evo owner that you must change out your fuel system (pump and lines) and there is a certain mixture you use with premium. He said theres actually a boost in performance with it.
Old Sep 18, 2008 | 12:44 PM
ThunderOZ's Avatar
yea it'll supposedly eat through your stock lines. There's a lot of info on it in the alternative fuel section in the Evo section. If you make the switch you might as well go fuel E85
Old Sep 18, 2008 | 01:31 PM
Thats it right there! I was confused between meth and Eth.
Ok. I got it now...So on the other hand it should be safe to run part METH and gasoline?
Old Sep 18, 2008 | 04:19 PM
Synthrocker's Avatar
E85 will eat right through your stock metal lines.
Stuff kills metal faster then salt ^_^
Meth on the other hand, havent a clue
Old Sep 18, 2008 | 06:17 PM
drucea's Avatar
People run meth all the time on evos. No one with a lancer yet. I'm sure there's plenty of tuning involved. But I believe you can run meth if you get the car tuned for it.
Old Sep 18, 2008 | 06:51 PM
ThunderOZ's Avatar
This is on an OZ
Old Sep 18, 2008 | 06:58 PM
JohnBradley's Avatar
This is exactly backwards actually.
E85 cleans the tank out and can plug the fuel filter but it doesnt eat through anything like steel or aluminum. Methanol on the other hand is highly corrosive to aluminum and can eat holes in it if left on exposed surface without running gas back through it. Methanol is also bad on rubber lines, gaskets, and seals. Ethanol hasnt caused any of these issues in any car we have done or my personal or Lucas' personal Evo.
To answer the other question...
To run E50 (or some approximate value) you will need to put larger injectors in, a fuel pump, and retune. At that point you might as well run straight E85 or E98 and then tune just for that. The octane level is rated at 105 motor octane for E85 and somewhere (depending on who you listen to) 113 and 120 motor octane. Remember that motor octane is the minimum value the fuel will be and research is the maximum. When we buy 91-93 octane it is an average of those 2 values.
Boosted cars thrive on it, and I would suspect a properly built NA motor would as well (higher compression and larger camshafts) if everything was developed around the fuel.
drucea's Avatar
Who is it and are they on here?
Old Sep 18, 2008 | 07:02 PM
4g94T's Avatar
more boost?
Old Sep 18, 2008 | 07:08 PM
vial8or's Avatar
Wow, barely?
go on socalevo.net
tons of ppl are running e85 as their DD gas. It's about the same as running MS109 race gas, and no it won't kill your lines, there's been tons of testing at RRE, TT, and many other evo shops in socal.
All you need is a fuel pump, injectors, and a tune. and whatever mods you wanna chuck on to get the most outta the gas
Old Sep 18, 2008 | 07:11 PM
Rnm's Avatar
Rnm
I just recently converted to E85 and I am in love. Only thing that sucks though is the gas mileage, but when I'm having this much fun and making a lot more power, I just don't care:
http://www.youtube.com/watch?v=tPplbXTV3eY
Old Sep 18, 2008 | 07:34 PM
RICAN RED 4G63's Avatar
Thinking Of Converting To E85 But Wondered Whats The Average Gas Mileage To A Full Tank And Per Gallon!!?!? By The Way This Thread Has Been Very Informative!!!
