The new Mivec 2.4L is weaker than the 1.6L Mivec overseas why?
I'm just curious why that the JDM
1.6L Mivec makes 170ps where as the ralliart Lancer only makes 162hp?
It's just hard to believe that 2.4L with variable valvetrain to be such a weak engine. Most 4 bangers in it's class has more horsepower less displacement and no variable valvetrain. I'm asking what did mitsubishi do to detune it so much. The engine should make at least 190hp for it's size.
1.6L Mivec makes 170ps where as the ralliart Lancer only makes 162hp?It's just hard to believe that 2.4L with variable valvetrain to be such a weak engine. Most 4 bangers in it's class has more horsepower less displacement and no variable valvetrain. I'm asking what did mitsubishi do to detune it so much. The engine should make at least 190hp for it's size.
is ps (what does that stand for) and hp the same thing? and if so, a 1.6L engine MUST be turbocharged to make 170ps IMO.
i'm hoping the 2.4L will be a very tuneable engine, with lots of power on tap from mods.
do you know what the new 2.4L mivec engine code is by any chance? i've just been wondering.
GIS for 2.4L mivec engine code...
http://www.mitsubishicars.com/2004ga...es_specs2.html
looks like its the 4g69.
OT (sorry, last one i promise)
engine codes (cool link)
http://dreamwater.org/eclipsedevo/enginecodes.html
Do you know what the torque ratings are for each motor (The 2.4L will have a lot more)?
Do you realize the 1.6L would never pass today's emissions?
Do you know where they each produce their peak power and if there would be a major difference if the 2.4L were a DOHC like the 1.6L instead of a SOHC?
The answers to these questions may provide and answer for you.
4G69 - Power: 121kW @ 6000rpm
Torque: 217Nm @ 4000rpm
4G92 - Power: 130kW @ 7500rpm
Torque: 167Nm @ 7000rpm
Why would Mitsubishi bother making a MIVEC engine with SOHC? This is a comparision of 1600cc vs a 2400cc and the 1600cc makes more power, surely with another 800cc the 2400cc should be better than it is? Maybe they should have continued with the 6A12 (2000cc V6 MIVEC) and got it to fit (should be shorter but wider) like some people do.
6A12 - Power: 147kW @ 7500
Torque: 200Nm @ 6000
Aston
Aston
The 4G92 may claim 175ps(~172hp) and 17kgm(123lb-ft), but power at the wheels of a Lancer MIVEC 1.6L with the 4G92 is a lot less than that. Try around 125whp and 90lb-ft for the real power at the wheels. With some basic ECU tuning you can gain 10hp and 10lb-ft at the wheels. The 4G92 is one of the most exaggerated power outputs I've ever seen.
btw ps stands for "PferdeStarke" and is German for "horse power". 1bhp = 1.01387ps
CTR: 185HP B16A Japanese Spec
US Civic Si sedan: 160HP B16A2
VTEC > Mivec
There is a Mirage cup in Australia, they run the Mirage cyborg with the 4G92 MIVEC in fairly close to standard condition (I think they have a ralliart ECU, probably exhaust) and I have read that they get close to 150kW (~200hp). If this is true they should have close to the 130kW in standard form.
Aston
Aston
evo_soul
Future Lancer / Evo Models
29
Dec 8, 2011 08:16 AM
Gts_BlackJoker
Lancer Engine Tech
23
Oct 13, 2007 12:55 PM
quantum
May 13, 2004 07:08 PM
