2004 lancer maintenance schedule
Old Jan 7, 2009 | 02:39 PM
lancerpimp08's Avatar
I am getting close to 60,000 miles. What should I have done?
Thanks.
Old Jan 7, 2009 | 06:19 PM
Richplaydo's Avatar
You should have someone read your owner's manual to you.
Old Jan 7, 2009 | 07:43 PM
Jellyfishian's Avatar
Sometimes when you buy a used car you don't get them.
If you have it, it will tell you everything you need. If you don't have it we can tell you or I can look at mine and tell you exactly what it says for 60K.
Old Jan 8, 2009 | 11:21 AM
I appreciate your help. The owners manual is great but I prefer to ask people what needs to be done in reality.
Thanks for being an *** right away.
Old Jan 8, 2009 | 03:38 PM
Then the major item at 60K is the timing belt. Is your car running fine? No SES? Other than that maybe your spark plugs and air filter depending on when they were last changed. Some people recommend you replace your water pump along with your timing belt, I did NOT replace mine when I had the belt changed and I have no issues to speak of at 80K.
Hope that helps!
Old Jan 9, 2009 | 07:54 AM
Hope that helps!
Thanks for the response. I have a KN filter so I can just clean that. I may change the spark plugs as well since they are easy to change.
Thanks for the kind response.
Old Jan 10, 2009 | 04:51 AM
Richplaydo's Avatar
Thanks for forgetting the search button right away. I have seen this question 100 times.
Old Jan 18, 2009 | 07:44 AM
If it has been asked 100 times, please provide me with 100 different links.
Thanks.
Edit: Only found 7 links
https://www.evolutionm.net/forums/search.php?do=process
reliablefr
18
Aug 30, 2012 11:46 PM
