Two Fans Behind Bumpers?
Old Feb 16, 2009 | 10:57 AM
kiu00001's Avatar
Hi guys,
I' just had a look at the car today and found that the two fans are not spinning even when the car is turned on. I've never actually take a look at it since the day I bought it, is it suppose to turn on its own when car is started? cause i see wires connecting to it. Thanks.
Old Feb 16, 2009 | 11:03 AM
nj_08_gts's Avatar
They don't run all of the time so it's possible for them to not be doing anything even while the car is running.
Old Feb 16, 2009 | 12:36 PM
Jellyfishian's Avatar
Turn on the A/C as soon as you do you will hear the fans operating.
Old Feb 18, 2009 | 07:35 PM
imajinmyfx's Avatar
cooling fan... it starts up when the engine gets hot. no point for it turning on when you just started the engine.
Old Feb 18, 2009 | 07:37 PM
amui07's Avatar
the fans don't run 100% of the time. Unless they never turn on, you don't have a problem
Old Feb 19, 2009 | 11:25 AM
OZ Rally's Avatar
Fans only turn on when the engine is hot or when you turn on your A/C
Old Feb 19, 2009 | 02:05 PM
03_Lancer_ES's Avatar
which is why you are supposed to disconnect your battery when you work on your car, partially anyway. So you don't get caught in the fans, as they can come on when the motor is shut off also.
lghtngyello03
10
Jul 22, 2016 03:26 PM
Spythere
Jul 5, 2016 03:09 AM
utggevox
Jun 10, 2012 04:30 PM
ralliartN20
Jun 7, 2008 06:34 PM
Noe18
13
Aug 20, 2007 08:14 PM
