Spectre Custom Intake
Old Apr 4, 2009 | 09:27 PM
suninthyhands's Avatar
Registered User
I have a Spectre intake. The Tubes are Plastic. What's better a Plastic Tube or a Metal one?
MIT Lancer ES 2003
Here is the link
http://www.picturetrail.com/sfx/album/view/20588827
Old Apr 6, 2009 | 03:24 AM
Fuze49's Avatar
The intake looks chrome to me but that may just be the paint on it. I prefer using a metal intake pipe. I don't really know if there is a difference but the plastic may run into heat issues and warp especially with mods that create a lot of heat like a header. My engine bay is on fire after I run the car for more than 2 minutes.
Old Apr 6, 2009 | 08:36 PM
nicdeloach's Avatar
they are plastic. the kind u piece together from like...autozone. like Fuze49 said ~ unless ur putting alot of heat in there, ur fine. the benefit of plastic, metal and rubber are debatable on such a short distance. the filter quality is the bigger factor. make sure tho u use the rubber washers that come with the connectors at least to seal it up.
btw: ur shorter setup u had in those pix is prolly better cause it is further away from the heat off the header and keeps the maf away from it too
Old Apr 7, 2009 | 02:32 AM
Registered User
Thanks for the advice. But I am putting a Heat Shield between the Engine, So that won't be a problem. And yeah I put the rubber Washers that came with the Tubes.
And yeah I did get it at Auto Zone!
marcusE
Jul 19, 2012 10:21 AM
catbiscuits
Cobb AccessPORT
13
Feb 7, 2012 05:10 PM
LRA_Joe
Jun 18, 2011 08:04 AM
Maxmumboom
Evo X How Tos / Installations
12
Jul 28, 2008 07:49 PM
Spectre23
Jan 25, 2006 09:55 AM
