Battery Relocation Question
Old Sep 19, 2009 | 11:21 AM
NixLancer's Avatar
Hey, you guys think 4 gauge wire is large enough to run as the power wire to the trunk? Or will not enough juice go through it? I live in wisconsin and it can get pretty cold in the winter. Anyone use 4 gauge before?
Old Sep 19, 2009 | 01:48 PM
03_Lancer_ES's Avatar
The juice will go through it, it's just a question of whether the gauge is enough to keep it from burning up your car. Search for it on here, it's been done, I just don't know the gauge.
Old Sep 19, 2009 | 05:17 PM
1lancer's Avatar
thats what i have and its going on its 2 year......and it gets pretty cold here..
Old Sep 19, 2009 | 09:23 PM
NixLancer's Avatar
Thanks! I think I'll go for it next weekend.
Old Sep 19, 2009 | 11:44 PM
Greell's Avatar
may i ask the reason for the relocation?
Old Sep 20, 2009 | 07:39 AM
NixLancer's Avatar
Just to clear up some space under the hood. And I ran out of cheap things to do to my car.
Old Oct 7, 2009 | 08:14 PM
Chameleonzero's Avatar
go to your local stereo install place and ask one of the mechanics and he will give you the best answer
Old Oct 7, 2009 | 08:46 PM
JRR's Avatar
JRR
where in wisconsin? im just north of madison. 4ga would do it, but id almost suggest 2ga imo.
josh
Old Oct 7, 2009 | 08:54 PM
SqEvoVIII's Avatar
A good Quality 4g will be fine, the wire from your alternator is barely 4g so there is no need to go any bigger. But like I said, good quality wire, multi strand wire and none of those crappy Walmart Amp Kits. My work sells Rockford Fosgate power wire or Monster would be my choices.
Old Nov 20, 2009 | 03:11 PM
pitbulllove2003's Avatar
battery relocation answer
i run 4 guage wire when i relocated my battery it works great i still would recomend a nice zero guage it is more expensive but it will give the best current flow but on a budget build 4 guage would be big enough like i said i ran 4 guage n i live in montana so it gets COLD in the winter here and HOT in the summer n i have never had a problem with it n its benn almost two years since i moved it
Old Nov 23, 2009 | 11:30 AM
ThunderOZ's Avatar
I'm not sure if you've done it already, but I've been running 4gauge wire on my little cheapo parts store battery, in the trunk, for about a year now.
Old Dec 4, 2009 | 09:52 PM
Spoolin4g63's Avatar
can yu guys post pics....!
Old Dec 5, 2009 | 12:25 PM
NOTORIOUSLANCER's Avatar
I wanna see pics also
Old Dec 5, 2009 | 08:09 PM
02-Lancer-Es's Avatar
If you all do this mod make sure you all put a main fuse on the positive terminal right after it is plugged to the battery , the reason people have burned there cars in the past is because they do not add the fuse and positive wire pinches something so it grounds out .
Old Dec 7, 2009 | 08:26 PM
senate6268's Avatar
I relocated my battery to my trunk into a Moroso battery box over a year ago. The Moroso battery cable kit came with 2ga wire. I have a distribution block mounted under the hood and a 120a fuse mounted in the trunk, inline, about 18" from the positive terminal.
When it comes to your car's electrical system, do it right or face a world of hurt if something goes wrong.
ahr4156
Jul 7, 2012 08:43 AM
sabastian458
34
Nov 14, 2011 12:56 PM
laxplayer14
Evo X How Tos / Installations
Apr 1, 2011 02:19 PM
evo4l
Mar 19, 2009 06:00 PM
dreamevo
Sep 20, 2006 06:50 AM
