Tight, rusted bolts
Old Jun 9, 2002 | 01:30 AM
HobieKopek's Avatar
Tight, rusted bolts
Anyone happen to have any really effective methods for removing bolts that are slightly rusted and VERY stubborn? I'm giving up on my socket set and about to bust out the flamethrower. The two bolts in particular attach my exhaust piping to my cat and are so damn stubborn that they must be related to me. Any suggestions? WD40 is having little effect. My locksmith friend suggested that if the Locksmith in a can (WD40) didn't work then to try pouring Coke on it. (Apparently Coke dissolves rust as well as it does the enamel on your teeth.) Too hard to do considering its location, I don't want Coke on my cat, and I'd have to lie in it to bolt everything back on. Any other suggestions?
Could use suggestions ASAP if possible because I'm sorta exhaustless right now and may end up having to steal my sister's car to go to home depot for a rubber mallot and a junk wrench.
EDIT: The car's up on jackstands, so keep in mind my limited work area too.
Old Jun 9, 2002 | 01:34 AM
DJPhattRoc's Avatar
get a can of 3-1 oil, or go to a local discount auto parts store and pick up a can of PB Blaster.....works wonders.....way better than WD40
Old Jun 9, 2002 | 01:43 AM
GPTourer's Avatar
Get Medieval on it
Man I had the same problem when I replaced the exhaust system
on my Eclipse. The downpipe/O2 housing at the turbo was the
most difficult part. The bad news is, they ended up having to
drill out the bolts and retap the threads. Sometimes thats the only way.
Old Jun 9, 2002 | 01:44 AM
HobieKopek's Avatar
Preciate the help, gents. I'm headin' out for the junk wrench, rubber mallot, and some rust annihilator.
Let's hope this goes well...I wanna avoid drilling/retapping.
Old Jun 9, 2002 | 01:46 AM
DJPhattRoc's Avatar
the pb blaster always worked for me hobby try it first when u get back.....be aware to let the blaster sit first, then spry again, then try and break it loose.....also are u taking off the cat?? if so.....if u do not have in the air, u need as much leverage as possible trust me
Old Jun 9, 2002 | 02:35 AM
Link286XT's Avatar
use air tools, there the best for stubborn bolts, if you dont have any im sure you can rent some, if not use a breaker bar with a cheater pipe, that works
Link
Old Jun 9, 2002 | 04:28 AM
HobieKopek's Avatar
VICTORY!
I WON!
My WD40, cheap wrench, and hammer idea worked wonderfully. The rust was only about 1/4 of the problem it turned out. I don't have air tools easily available, but I do have my humongous muscles. ::flexes::
Yeah...not really...but the vibration supposedly helps loosen and the car wasn't too rusted (I mean...I've only had it since mid January) so it came off no problem and went back on tight. Cleaned the nuts and bolts with a bit more WD40 and hopefully it will prevent future rusting. Fun fun fun!
Good luck to those of you putting on cat-backs in the future.
Old Jun 9, 2002 | 04:29 AM
HobieKopek's Avatar
And most importantly...thanks for all the suggestions, guys. Even though it didn't come down to it for me, I'm sure other people will make use of them in the future. (Assuming they don't just post the same exact question as I did...which is honestly a lot more likely than not. )
Old Jun 9, 2002 | 09:28 AM
b_tapper's Avatar
A can of white lithiym grease...fixes everything...well almost...
Gotum209
Lancer Troubleshooting
10
Apr 10, 2011 08:51 PM
Ralliartize It
Jun 23, 2010 09:59 AM
karlzhot
Jul 3, 2007 03:38 PM
