4G18 Problems. HELP!!!!!
Old Dec 12, 2012 | 02:12 PM
4G18 owner's Avatar
Unhappy 4G18 Problems. HELP!!!!!
Hey can anybody help me. I have a CS3 Singapore Lancer 1.6 the car went to electrician to fix the switch for the lights because it was shorting. When I went to pick it up and start my car the car refused to remain idling and only plugs 3 and 4 receiving electricity. The car was taken to another electrician and he diagnosed the problem to be the ECU. So I bought a foreign used ECU unfortunately not with the matching serial numbers but the boards match. So we put in the new ECU and the car is idling now and all pistons firing however the much air is not coming out of the exhaust (just barely) and the fans are not spinning unless the AC is on. What is happening? Any suggestions?
Old Jul 4, 2015 | 12:37 PM
gilbertoavilez7's Avatar
Ecu could be off on timing. With stock exhaust i can feel gasses hitting my legs from like 3 feet away on my 4g18. The fans wont activat without engine passing normal operating temperatures. If engine is over heating and they dont activate than check your cooling system entirely from the fans and relay box to water pump and thermostat. I rebuilded my engine and skipped the water pump to save money and that was a costly mistake had to rebuild again after wate pump failure. Oh and also check air to fuel ratio wich can also be the problem do to ecu not from your car. Good luck
Old May 11, 2017 | 11:52 PM
Sekky's Avatar
สูบเดินไม่ครบ เป็นที่ระบบไฟ ใส่ Direct Coil ของ K20 หายแน่นอนครับ.
S.Brewer
May 14, 2018 08:15 AM
SLESLIE
Lancer Tranny/Drivetrain Tech
Nov 17, 2017 08:12 AM
evocrunch
13
Nov 6, 2017 01:07 AM
TariqEvo
Jul 28, 2017 12:12 PM
dymmy
Apr 2, 2016 06:33 AM
